Re: Suzuki's New Premium Hatchback Baleno Now Launched!
^^Yes sirji, the warning symbols before you turn the ignition on are all normal. In case there is anything wrong then the warning symbol will either remain on after turning ON the ignition too or the ignition won't happen.
NCR
Is the battery sign in RED normal (before start of engine)? not able to upload image
Yes. But it should go OFF within seconds of starting the engine.
TSIVipul - Okay, I have to agree that Maruti needs a lesson or two on designing a more comfortable car from Honda and Hyundai. Now tell me if anything is possible in aftermarket to solve this issue, like seat covers with extra padding or stuffing foam in them.
ChandraV - Maps are loaded in the HU from an SD Card at first. Then you can use navigation and navigate the world (err.. India) in your blockbuster Baleno! [lol] And that 7" touchscreen is same as in Ciaz and Ertiga I guess. It plays CD also.
no we don't have CD slot for alpha model.
for Navigation, its simple to use, first enter your SD card in the slot, then select state,city,area and pin code(not mandatory) where you want to go, by touch screen, that's it, system will guide you there from your current location. it will also show nearer petrol pump and other shops( i guess ATMs also), places of interest etc.
Saarji the car will be driven by your mother and I doubt if it will be used for day long journeys or say looooong trips. So no use adding anything, they are comfy enough not to kill anyone on the trips between say Meerut-Gurgaon or Dehradun.
Nexa Baner seems to have some issues.
If you get a call from Maruti Insurance, it means your car insurance has been registered. Dealers often do this- they register the insurance even before the car leaves their stockyard. That way, if there is any issue, they can claim insurance in your name. Its both good and bad- you get lesser days of insurance cover since you haven't gotten your car delivered but it also means the car is in transit.
Ask and insist on a preregistration inspection. Tell them you will stop payment and loan disbursement if they don't offer it
Ameyam
Yeah Sai Service NEXA Baner Pune has some issues by seeing the number posts against them in this forum and others.
Pune has 3 NEXA dealerships and I haven't heard anything specific about other two where people are pointing bad experience and RMs by quoting names.
Payment is already made as they told to deliver the car on 16th. [frustration]
Isn't it the case that to register the car they would need the insurance and they wouldn't go for insurance or registration until full payment is made.
Unfortunately since 16th they are telling me one thing or the other about registration. You have a point, car could be in transit and they just initiated the insurance.
By the way those seat and steering covers really look nice and sporty. [thumbswink]
How much time did the guy take to make it?
You will recv two sms from RTO
First one of receiving tax amount
Some thing like
Tax Rs.XXX received for New Registration, chassis No.XXX (Receipt No-XXX) on DATE Thanks...RTO, PUNE
Next day you should receive
2nd one for allocating reg no for your car something like
Reg.No. MH12 XXXX is allotted to chassis No-XXXX on DATE. (Receipt No-XXX) Thanks...RTO, PUNE
For me it took 3-4 days after submitting all required documents. Please check with RM if any document is missing from your side or they misplaced anything
Thanks @atlex123!
So far I have received none and today is 4th working day since the registration papers were sent by the dealer. I doubt that RM ever sent it. As @ameyam said, car could be in transit.
Sorry sirji, that explanation is not good enough to explain the poor placed, padded and shaped rear seat. You have got a DZire back home and it is also a car with tight leg and headroom but isn't the seat well placed, padded and well shaped? Especially in the sub-4m DZire which we have now, older one had better legroom but newer one has better rear seat.
I call that design flaw!
Not giving enough thought while designing the vehicle. Honda and Hyundai have gone a different way and have finally obtained a better rear seat (Way better indeed) at slight cost of legroom (Well acceptable though). MSIL could have used slightly bigger seat base (Maybe an inch or so) and slight change in the seat design; be it seat base or backrest and they were done but they have decided to use scissor here. Sense of legroom with a compromised seat[lol]; now select one of the two - either have a better seat or have a lot of legroom.
Placing it even lower would have made people sit with knees pointing towards sky I guess. IMO they just needed to change the shape; the hip point is actually at the place where it should have been; they just could have used a bit more foam for under thigh support (Ala DZire) and that would have solved the problem. Legroom is already enough, with same seat height, no headroom issues and the under thigh support issue also would have got solved.
Flexing when pulled towards inside with the doors closed is there in nearly every car at least under 25 lac price bracket. Flexing of the doorpads when arm kept on door armrest (Which never happens in Baleno) or while windows operations (Ford Figo has it) etc are what point towards flimsy pad build. Rest slight flexing will be there in nearly every car when you pull the doors from inside where they are in shut position. Corolla has that, laura has that, Innova has that, Polo has that, i20 has that..ehh nearly every car has that.
C'mon guys, door pads are not supported with reinforced metal and have nothing to stop them from flexing when you pull them inwards, check on how they behave when you push them outwards; especially the part above and under the armrest.
No complains against Baleno in this aspect, I haven't found anything wrong with the doors and their pads. They are finished better than DZire, door armrests felt better placed, shaped and padded and button, handle etc placement is also brilliant.
If your hands sweat a lot then better get something to cover the leather steering cover else within an year of time you will have a really bad looking leather steering cover. I have this problem and the wheel cover of my Corolla started looking too much worn off within an year itself. Now I always have a small sized towel placed on my lap and the problem is solved for now. On my Polo I have the leather wrapped wheel and its just a 14 days old car but the wheel has now itself started showing the negligibly minor signs of slight wear because of sweaty hands. This is the stock wheel and I will be getting a high quality and super durable leather cover for it whenever I am free:
The people at yard have tried to fool you saarji and you even agreed to what they said, hence proved: they have succeeded in fooling you.[lol]
Please go through the jhol-jugaad written above.
Excellent understanding, keen observation, good in technical aspects. I agree all your points except door pads and its design is good in dzire.
To be really fair, I don't have any complaints with the fit and finish of the Baleno...currently.
Just as a note- the call to confirm my insurance came on the 8th and my insurance started from the 8th even though my car was registered on the 10th and delivered on the 12th.
Regarding the steering cover, I don't have sweaty hands, just I don't like rubbing sounds. As I slid my hand over the wheels while turning, it made a rubbing sound which I didn't like at all. Also, when I was twirling the wheel back and forth in trying to park a new car which I didn't know the extent off, I kept losing my grip. So I went for additional wrapping over the original leather one. This one is not like the one in the swift that the ASC had installed. That one was soft and really grippy and I could even use the back of my hand to turn the wheel. But it began to lose its paper cover in an year. The one on the Baleno is harder material and I cant use the back of my hand to move the wheel but it is still grippier than the stock. Didn't remove the stock one, this goes over it
Ameyam
Now Saarji what to say, we engineers are always awesome :tongue:
I never said that DZire has them bad. It's a Maruti and the ergonomics are like any Maruti - spot on.
All I meant was "Baleno betters them".
Rest I am also sailing on your boat, a Swift ZDi frequently becomes becomes my chariot for many site visits and I also will prefer a Swift any day over a Baleno. Not for anything else but for the brilliant and comfy seats (Baleno doesn't have that good seats) and the sharp turn-in which has always been the best characteristic of the Swifts' handling.
You need more time with the Baleno and more a heavier foot on the accelerator
Ameyam
Ice_wise, when was the last time you had used a CD in your car. The last I can remember was when I was using the HU on my WagonR that didn't have a USB socket
Ameyam
Hyd / Bang
Got first Service done.
Amount - 0.
Boot door sensor button was not sitting in its place and was coming off. Complained about that. They have adjusted it but i was still demanding for a replacement for which they obliged and put order for the part as it is not readily available. But sour point is, it might arrive only after new year due to Holiday period.
There is no specific bay for NEXA vehicles in regular Maruti ASCs as I read somewhere. The vehicles were being serviced alongside swifts, altos, wagonRs etc.
Nice to see that the Service History got updated in the NEXA app with KMs and Date of Service along with the dealer Name.
Also I have asked the SA about the auto rollup of windows. He called to couple of showrooms (Not sure if they are Nexa Showrooms or any other) and confirmed that it is not available for Baleno. I asked if Swift / Ciaz doesn't use the same power windows internals of Baleno for which he said NO.[surprise]
Anyone confirm me if Baleno gets a Remote for Infotainment System ? I have seen the remote for Ciaz and a storage pocket in the front passenger seat specifically for the remote.
- Sandeep
Image Courtesy - TeamBHP
I understand majority are going in for Ray Blue color
, however I just wanted to get a more specific idea and views as to which is the best color in Baleno according to the following criteria--
1)Pure Looks?
2)Long term maintenance and practicality?
3)Resale Value?
hyderabad
Envy [evil]
Although my Polo is yet to do even 1500 kms but I am aware that at 15k kms or first service, the VW guys are gonna make a break into the bank to pay their bills. Not even a single free service [cry]
got first servicing done
amount 0.00
they came all the way to my house , done servicing and cleaned the car and gave free token for car water wash
please check seat covers for my alpha baleno , total cost 6k , not from NEXA
