Re: Maruti 800: Technical Issues and Solutions
Thank You bros. My requirements are not much just a basic music player with 2 speakers. Maybe will upgrade to 90/100 head lamps. if this solves the purpose of better lighting, will not get the fog lamps.
One query though, If I upgrade to 90/100 headlamps, will the stock alternator/battery be able to take the load?
Also, how to access to change the parking lamps?
Thanks
Stock dynamo is 30 or 35amps only, it will start to give problems within few days from the day you install the high power headlamps. You can buy a new TVS lucas 40amps dynamo (specify that you need it for a m800) & you can install it easily
Pros:
Good enough for a normal Maruti 800 car with these accesories
100/90bulbs, basic ICE, simple horns, no crazy Lightings etc
Cons:
Cant support woofers, Amplifiers, extra fog lamps etc
Cost: about - 3500/- to 4000/-
Best brands:
TVS LUCAS / DENSO (Both are OEM suppliers too). The dynamo can last over 10years if installed new.
Few pics of the 40amps dynamo I am mentioned
Harish:
The best & easiest way to warm up the engine is to do this, since yours is a MPFi car
1. Start the car without pressing throttle pedal
2. Let the car idle in neutral for about 30secs atleast
3. Start driving the car at low speed for a few hundred meters & then drive the way you usually do.
4. Do not practice the method of "raising engine RPM" before switching off the car.
