Speakers For Maruti Suzuki Swift VXi
Sorry tushar, my bad
What you have bought are Renegade (which is a Rockford brand) speakers. If your listing (from where you bought them) was for 1693, I would return the item as not as per description. If not, you did not buy the intended speakers, you will need to bear with them. I read a few reviews and they seem to be ok
Amazon.com: Customer Reviews: Renegade RX693 6 x 9 Inches Full Range 3-Way Speakers - Set of 2 (Black)#
http://www.amazon.com/Renegade-RX693-Inches-Range-Speakers/dp/B0045SS474
Ameyam
Thread Starter #32
palwal
Amazon.com : Renegade RX693 6 x 9 Inches Full Range 3-Way Speakers - Set of 2 (Black) : Vehicle Speakers : Car Electronics
Ameyam
thanks bro but i bought r1693 but he sent r693 and also i have fitted them in my car and wiring has been cut so will they accept it back
They wont accept it back now. Always remember that if what they deliver is not the same as listed, all these sites have a return policy. If you have already modified, you are stuck with them
Ameyam
Thread Starter #34
palwal
Ameyam
I am satisfied with them bro but i coud not remove my resr speakers the guy told me cutting would be done to remove rear speakers of doiors so now i m running
All 6 speakers now is there any socket available with ehich i can disable rear door speakers
Thread Starter #36
palwal
That's real weird. Why cant they remove preinstalled door speakers? Try going to another fitter
Ameyam
bro when he opened the side panels door speakers were connected through white socket so how will they be removed? you have to cut wires out of the socket to remove them if you know any alternative to this it will be very helpful as i want to remove the rear door speakers
Swift V trim comes without speakers. In either case, speakers are not directly connected to the wiring but through two part sockets (male - female socket). So to remove, you pull off the speaker side of the socket & you are done.
Ameyam
Thread Starter #38
palwal
Ameyam
how will the rockford speakers be connected then? if socket is removed
Not the whole socket, only the mating part. So if the female part is connected into the car's wiring harness, they will take a mating male part and connect it to the speakers, then insert into the female connector.
With regards to how the parcel tray speakers will connect to the door socket, I have really no idea. The swift is really designed for door speakers, so I guess if you intend to install parcel tray speakers, you need to run the wiring down to the door socket.
By the way, running the HU with 6 speakers instead of 4 may overload the HU if you are not running an amp
Ameyam
NCR
Bro overloading hu means? And i will go out of city to get this done as here all are amateurs
I think you have messed it up. Please revert back on what all equipment you have in the car now. What are you willing to remove/add? Are you okay with parcel tray fitment? Which speaker sizes are you having for front and rear? Which variant is your Swift and which model year (means did it come with factory fitted audio)? How are you running 6 speakers off a single HU?
See, HU has 4 outputs for 4 speakers. Most probably you have already cut the wiring and tapped it to add another 2 speakers at the back, which is not advisable as you are running 4 speakers (high power) in a wire designed for 2 speakers. You are stressing the HU (if gives out 10-15w RMS and your 4 factory speakers used to take that. Now you have added 2 more speakers which would mean that the HU is giving its 100% most of the time) as well as the wiring (by taking more current than it can handle). Please discuss this matter before your wires give up, which can have nasty consequences.
Thread Starter #42
palwal
no wire was cut during the installation
NCR
Then can you mention how 6 speakers can be connected to 4 outputs? Currently your wiring and HU are at risk. Wire may give up and melt because of additional current draw and internal amplifier circuit of HU will fry due to overloading/heating due to extra speaker load. Your installer has wires the extra 2 6x9 speakers in parallel with rear/front stock speakers. Either he has cut the wiring without your notice or attached the wire in between the coupler.
You are not getting proper sound effect as your speakers are not getting adequate power. The HU puts out around 15w for each speaker and the speaker demands much more power (as currently power requirement has added up because of 4 speakers at back). You simply have to get the door pad opened and remove stock speaker (or its connection) and let the stock wiring power the rear 6x9 coaxial only. Not a big problem.
Thread Starter #44
palwal
thanks bro but he said that if u want to remove rear door speakers he would have to cut the wires.i want to remove them can you help me?
NCR
Thanks bro but he said that if u want to remove rear door speakers he would have to cut the wires.i want to remove them can you help me?
Your installer is totally wrong. It would be better if you visit Faridabad or Delhi for correcting this install as installers are more experienced here.
Anyway, open the door pad (or get it opened) and unscrew the speaker nuts. As you start taking the speaker out from the door location, you will find that it is held there by wiring. That wiring would be joined to the speaker terminals (back side) by a white connector. Now that connector needs to be removed. If you can go till this stage and post the picture of the type of connector it is, I will help you to remove it. But actually it is very easy to remove the connector, you have to try and seperate it by pushing required pins, or applying pressure from certain areas. This way you can remove the connector by pulling it out and you can take the speakers out. If your 6x9 speakers stop working after removing the connectors, you will have to add a coupler to the 6x9 speaker wire. This coupler would be a male part and would be connected to the white connector (female part) to avoid any wire cuts. The male part of coupler which you will get from a good audio shop will have 2 wires which can be easily cut and taped to the 6x9 speaker wires. And all this would not affect factory wiring.
I have tried to write everything in the most easy way. Sir do you remember how exactly the wires have been connected for the 6x9 tray speakers? Is it stuffed between the contact points of the white connector?
