Here is the stuff that I got, the attachment bolt is a customized one. The screw thread was big on the backing plate and that bolt is so thick in diameter it didn’t fit into the drill head, so had to cut off half way of the bolt to reduce its thickness. You can see the bolt in the pic.
I tried this once, just working fine, the speed is an issue like I said and I have to be very careful, the drill trigger switch as much you press it will increase the speed.
Later I will try to get a DA polisher if available online with good pads.
