Re: HELP! New Maruti Wagon-R Idle Issues
YA i agree, paper filter filters well, but Even the paper filter let the particle inside.
A properly well maintained K&N filter wont cause you any problem because of the dust particles entering through it, since those particles are not big enough to damage the engine and wont need any "daily engine rebuild".
I think you never had a K&N filter in your car. If you dont, get to some of your friends who uses K&N in their vehicle
1) Check the condition of the airbox after the filter.
2) Check the inside and outside of the K&N filter. Outside surface of the filter will be dark in color due to the collection of dust particles, where as the opposite side of filter surface will be superclean and the color will be almost the same as newly oiled filter. It means the dust particle dont even reach to the opposite side.
A cone filter can performance better than a stock replacement filter.
But my question is whats the difficulty for you to accept the performance difference between the stock vs stock replacement K&N filters that I have stated from my EXPERIENCE??? It is not just from the information that i have collected from internet or from my friends. Its really bad when you blindly discourage it.
My friends dont face any kind of issues, one of my friend's swift(similar to a-stars airbox) is running close to 1lac kms in his K&N. All of them dont have any issues like mileage short or any kind of low performance.
"You are wrong, I am not blaming K&N.They do make a good product is it really good for everyday use is my question."
No man, you are really blaming the filter K&N. Or else what you mean by this question?
Is it that "yes they make good products, but they are only good for weekends driving" ?
By comparing to the race engines, You are talking in such a way that a daily driven K&N engine must need more frequent engine rebuilds for maintaining the engine in its better shape.
By comparing to the cotton cloths you have said it looses its property after its first wash. I didn't ever hear this in my real life or in my experience. Even in the internet its really hard to find a damaged K&N filter reported by any customer. If you found any please be sure to find the reason for them for not asking for a replacement.
Please Answer to these questions
1)According to you, approximately after how many kms these engines starts showing the lack of performances ?
2)After How many kms these engines requires a rebuild?
"I do not know how they handle engine failures in the US .But I am sure a lot of passing the blame happens there as well."
That is the Mystery behind the blaming people. they just need to blame.
I have searched a lot, What all i can see is people blaming about K&N for ruing their engines. But I didn't find a customer reporting it to the K&N and rectifying the engine failure. Or about experiencing the poor customer service when asking for a warranty claim. So for these reasons we can say a minimum of 80% of blames we see over internet are fake.
Again you are speaking too much about 0W-40. Tell me in what language should I say Mobil1 do only have 0w-40 as fully synthetic engine which is suitable for the KB10 engine for reducing the IDLE vibrations.
"So according to you only 0w40 provide good cold starts?Why are the other grade of oils even made?All multigrade oils have good cold start protection.If you idle your car for a few minutes after you start it, there will be less damage with 5w30,10w 40 and 15w40 and 20w40.The cold start temperature condition depends on the environment temperature.Do you understand this, even if it goes to -40°C then with 0w40 you start and can drive your car without the engine ceasing due to the oil freezing.
Down south does the temperature go below -40°C outside?No.
Based on the temperature outside and using the viscosity range provided by Maruti any oil that suits the temperature range in your area of choice will provide protection from the time you turn on the key.
For example, if it is 30°C outside do you think the engine is going to be frozen that a normal 15W40 oil will do damage at cold start?No"
Does Any of your statement proves that 0W-40 is a bad choice for the KB10 engine so as to damage it?
->No, You are misspelling. I didn't say 0w is the ONLY engine oil which helps in cold start protection, Instead i said "Lower the cold viscosity higher the cold start protection" So 0W oil not going to hurt this KB10 engine in anyways.
I'm not an expert in fluid mechanics, then also i'm trying to answer to your above questions with my limited knowledge.
->After Idling the car for sometime even the 40grade oil is far enough to protect the engine from wear and tear. If you only consider the engine wear few minutes after starting then why you are putting multigrade oil?
->Lower cold viscous oils are costly. so If the car manufacturer dont insist to use a 0W-XX grade oil, then the customer can go for more affordable oil.
->You are wrong, all multigrade oils wont give you better cold start. There are 30w-40 multigrade engine oil. here the grade 40 lies in the preferred hot viscous range for KB10 engine. where as the 30w is not.
->Everybody know that a lower viscous oil makes the engine strain. But I cant understand how a 0w-40 gets more strained comparing to 15w-40 or 20w-40. then whats the logic behind the MULTIGRADE OIL,? I don't think cold viscous has any role in the case of "engine operating temperature".
In my experiences with the 0w-40 and 5w-30, if feel the engine is more smoother and silent with 0w-40. So seriously i don't think cold viscous has any role in the engine operating temperature, but only the hot viscous grade defines.
"If you look closely at your service book's service limit page, you will see the spark plugs need to be inspected and cleaned at regular intervals and the gap needs to be checked as well.Ignore this at your own peril."
Yes I admit it. Just like the normal customers I too dont have tools for removing and checking the spark plugs , instead just like most of the normal customers i too give my car to MASS for the regular services.(With the hope of getting better services)
"As for the mileage.I was getting 20 with copper plugs, 24 with platinum plugs and 24 with Iridium plugs.No difference there.The high jump you see from copper to platinum is due to the addition of extra ignition coils.Rs200 plugs and Rs650 plugs are giving me the same output.Now what?"
I have already told you that I dont know much about the platinum plugs and in any of the posts I did't even mention iridium is much better than platinum. then why are you keep on questioning me about the platinum
The comparison i made with the stock vs iridium plugs.
Its good to know platinum also performs well just like the iridium. but what about the expected life of platinum and iridium?
If platinum can perform well like the iridium and with a half life of iridium, then its better to go for platinum itself.
You have missed some Questions.
"Whats the recommended grade of engine oil for Ertiga? Isn't it the same 5w-30?
I still cant understand why you are more conscious to get higher cold viscous oil even which is out of the range recommended by the manufacture. What benefits you get from it, can you please explain your view?"
"PS:On a side note, we have gone way off topic here.I guess we can continue this discussion else where."
Extremely sorry to all those members who are visiting this thread.
Jarpickle, If you still can't digest my answers then let me know the thread where we can continue, i will be there.
I also request you to tell me the answer for the above few questions in it.
Regards.
Regards.
