Getting a Low Mileage on Esteem
I have a Maruti Esteem car. Recently I have noticed that my car is giving a very low mileage than usuals. Though I feel that the clutch plates of my car could be a problem. Is there anyone who can help me with ideas what could be the other reasons for low mileage?
Thanking you
Noida
Re: Getting a low mileage
The usual suspects for a low mileage are : Worn out clutch, clogged air filter, low Tyre air pressure, dirty spark plugs, clogged throttle body, adulterated fuel. Isolate each one of them one at a time and try to narrow down on the cause. Getting the car to your regular mech would also help. BTW, are you facing low/restrained pick-up too?
freakdude.
Calcutta
Hi nycvanlimo ,
Apart from what freakdude mentioned , also check for brake dragging , which means the brake pads or the brake shoes don't retract back to their original position after the brakes have been disengaged .
Also do a compression test of the cylinders to check the wearing of the piston rings .
Please do mention how many kilometres has your car run till date and if the car is in stock condition or have you modified it in anyway .
Drive Safe
Spinner-Wheelz
