Coverage: Auto Moto - Kuwait Motor Expo 2016
Thread Starter #61
Kuwait, KL03
47. BAIC A523T
BAIC stands for Better And Ingenious Choice
  • Length x Width x Height (mm) 4861 × 1820 × 1462
  • Wheel base (mm) 2755
  • Curb weight (kg) 1590
  • Max .speed (km/h) 220
  • Acceleration 0-100km/h(s) 9.8
  • Model L4,water-cooled,Turbo
  • Displacement (ml) 1992
  • Max.power (kw/rpm) 150/5000
  • Max.torque (N.m/rpm) 290/1800-4500
  • Drive code FF
  • Transmission type 5 speeds: auto with manual mode with sport gear
Thread Starter #62
Kuwait, KL03
48. Renault Duster PE4x4
  • 1600CC 16 VALVE ENGINE
  • 77kW at 5 750 r/min and 145 Nm of torque at 3 750 r/min
  • of the driver’s solicitations.
  • Stylish roof rail
  • Stylish roof rail
  • Double Barrel Headlamps
  • Two tone coloured bumpers
  • Chrome Front Grille Surrounds
  • Tail gate chrome garnish
  • Door side sill
  • Tailgate Chrome Garnish
  • Black door handle finish
  • Black Outside Door Mirror
  • Classic Black Seat Fabric Upholstery
  • Chrome gear knob finish
  • Metallic Grey Centre Fascia Finish
  • Charcoal Grey Floor Console Finish
  • Glossy Metallic Grey Door Trim Decorative Strip
  • 3-dial techno sporty instrument cluster
  • Black & Grey Interior Colour Harmony
  • Front Power Window with Illuminated Switches
  • Front Only 12 V Accessory Socket
  • Headlight ‘On’ alarm
  • Front seat back pockets
  • 2 Cup holders
  • Versatile rear parcel on shelf with storage space
  • Passenger vanity mirror
  • Digital clock
  • Front reading lamp
  • Theatre dimming interior lamps + key answer back function
  • Trunk room lamp
  • Electric backdoor release
  • One touch turn indicator
  • Power steering
  • Engine immobilizer
  • Central locking
  • Engine protective underguard
  • Door open warning lamp
Thread Starter #63
Kuwait, KL03
49.FIAT 500 X
  • ENGINE: 1.4-LITER TURBOCHARGED MULTIAIR I-4
  • Type and Description: In-line four-cylinder, liquid-cooled, turbocharged
  • Displacement: 83.48 cu. in. (1,368 cc)
  • Bore x Stroke: 2.83 x 3.31 (72.0 x 84.0)
  • Valve System: Belt-driven, MultiAir, SOHC, 16 valves, hydraulic end-pivot roller rockers
  • Fuel Injection: Sequential, multiport, electronic, returnless
  • Construction: Cast-iron block with aluminum-alloy head and aluminum-alloy bedplate
  • Compression Ratio: 9.8:1
  • Maximum Turbo Boost: (psi / bar) 22 psi / 2.49 bar
  • Power: (SAE) 160 hp (119 kW) @ 5,500 rpm
  • Torque: (SAE) 184 lb.-ft. (250 N•m) @ 2,500-4,000 rpm
  • Max. Engine Speed: 6,500 rpm (electronically limited)
  • Fuel Requirement: 87 octane (R+M)/2 acceptable 91 octane recommended
  • Oil Capacity: 4.0 qt. (3.8 liter) with dry filter
  • Coolant Capacity: 5.5 qt. (5.2 liter)
  • Emission Controls: Dual three-way catalytic converters, heated oxygen sensors and internal engine features
  • Fuel Economy: 2WD: 1.4 L, Manual 6-spd: 25 mpg City/ 34 mpg Highway / 28 mpg Combined
Thread Starter #64
Kuwait, KL03
50. Mitsubishi Outlander 2016
Loaded with Signature Features
  • Engine Type 3.0L MIVEC SOHC 24-Valve V6
  • Horsepower 224@6250rpm
  • 7-passenger seating
  • Super All-Wheel Control (S-AWC)
  • LED headlights
  • Power remote liftgate
  • FUSE Hands-free Link System® with USB/iPod® port
  • 18-inch two-tone alloy wheels
Thread Starter #65
Kuwait, KL03
51. SILVERADO 1500 LT2 Single Cab/Std Box 4x2 2016
  • Engines 4.3L EcoTec3 V6 engine
  • Transmission 6-speed automatic transmission
  • Automatic locking rear differential
  • Exhaust, aluminized stainless-steel muffler and tailpipe
  • Rear wheel drive
  • Transfer case with floor-mounted shifter
  • Hill Descent Control
  • Steering, Electric Power Steering (EPS) assist, rack-and-pinion
  • Daytime Running Lamps
  • Dual-stage frontal and side-impact air bags, driver and front passenger and head curtain and seat-mounted side-impact air bags, front and rear outboard seating positions
  • Front and Rear Park Assist
  • Lane Keep Assist
  • OnStar Guidance Plan for 6 months1
  • Rear Park Assist
  • Tire pressure monitoring
  • All-weather floor mats
  • Console insert organizer tray
  • Rear Under-seat Storage
  • Airbags
  • Audio system with 4.2" diagonal color screen with AM/FM, USB ports and auxiliary jack
  • Chevrolet MyLink® audio system with 8" Diagonal Color Touch screen
Thread Starter #66
Kuwait, KL03
52. NISSAN Maxima SR 2016
  • Name VQ35DE
  • Cam design DOHC
  • Orientation Transverse
  • Cylinders / configuration V6
  • Block / head composition Aluminum / Aluminum
  • Displacement (litres / cc) 3.5 / 3498cc
  • Displacement (cubic inches) 214.0
  • Horsepower 300 @ 6,400 rpm
  • Torque (lb-ft) 261 @ 4,400 rpm
  • Bore & stroke (mm) 95.5 x 81.4
  • Compression ratio (:1) 10.6
  • Spark plugs Double-tipped iridium
  • Maximum engine speed 6,600 rpm
  • Induction system Sequential multi-port electronic fuel injection
  • Engine mounts (6 mounts per vehicle)
  • 2 vacuum liquid filled with membrane;
  • 1 right side liquid filled; 1 left side
  • solid; 2 solid w/anti-torque rod (upper/lower)
  • Recommended fuel Premium unleaded
  • Emission certification level 50 state: LEV3-ULEV125
  • Exhaust Type Centre and two main mufflers,
  • Dual chrome exhaust finishers
  • Drive configuration Front engine / Front-wheel drive
  • Transmission type Xtronic with manual shift mode, DStep logic and sport tuning
  • Traction Control System (TCS) S
  • Vehicle Dynamic Control (VDC) S
  • Gear ratios (:1) 2.413 – 0.383
  • Reverse gear ratio (:1) 1.797
Thread Starter #67
Kuwait, KL03
53. Geely Emgrand EC8
  • Engine Size 2.4 L
  • Displacement 2,378 cc
  • Number of Cylinders 4
  • Number of Valves 16
  • Transmission Category 6-Speed Automatic
  • Performance Power Train Front-Wheel Drive
  • Max Output (HP) 154 hp @ 6,000 rpm
  • Max Torque (nm) 213 Nm @ 4,000 rpm
  • Acceleration Rate 9.5s
  • Top Speed 182 km/h
  • Driver's Airbag
  • Front Passenger's Airbag
  • Side Airbag
  • Curtain Airbag
  • Knee Airbag
  • ABS With Electronic Brake Force Distribution
  • Immobilizer
  • Security Alarm
  • Stability Control
  • Electronic Door Locks
  • Speed Sensing Door Locks
  • ISOFIX Leather Upholstery
  • Lane Departure Warning System
  • Blind-Spot Detection System
  • Cruise Control
  • Front Parking Sensors
  • Rear Parking Sensors
  • Push Start Button
  • Wheel Size 17 in
  • Wheels Metal Type Alloy
  • Airconditioning System Manual Air Conditioning
  • Entertainment System Stereo CD, MP3, USB Port
Thread Starter #68
Kuwait, KL03
54. BMW X6 M
  • Engine & Performance
  • BASE ENGINE SIZE 4.4 L CAM TYPE Double overhead cam (DOHC)
  • CYLINDERS V8 VALVES 32
  • VALVE TIMING Variable TORQUE 553 ft-lbs. @ 2200 rpm
  • HORSEPOWER 567 hp @ 6000 rpm TURNING CIRCLE 42.0 ft
  • Four-wheel independent suspension
  • Front and rear stabilizer bar
  • Multi-level heating passenger seat
  • 14 -way power passenger seat
  • 14 -way power driver seat
  • Passenger seat with power adjustable lumbar support
  • Multi-level heating driver seat
  • Driver seat with power adjustable lumbar support
  • Height adjustable driver seat
  • Height adjustable passenger seat
  • Leather Bucket front seats
  • Cruise control
  • Front and rear cupholders
  • Front and rear door pockets
  • Front seatback storage
  • Electric power steering
  • Universal remote transmitter (for garage door, security system, etc.)
  • Front and rear parking sensors
  • Tilt and telescopic steering wheel
  • Transmission, cruise and audio controls on steering wheel
  • Rear view camera
  • Hands-Free Calling
Thread Starter #69
Kuwait, KL03
55. Infiniti Q60 Convertible
  • Engine: 3.7L DOHC 24V V6 -inc: Variable Valve Event and Lift (VVEL)
  • Transmission: 7-Speed Automatic w/Manual Shift -inc: Downshift Rev-Matching and Drive Sport (DS) mode
  • Rear-Wheel Drive
  • 3.36 Axle Ratio
  • 54-Amp/Hr Maintenance-Free Battery w/Run Down Protection
  • 130 Amp Alternator
  • Gas-Pressurized Shock Absorbers
  • Front And Rear Anti-Roll Bars
  • Hydraulic Power-Assist Speed-Sensing Steering
  • 20 Gal. Fuel Tank
  • Dual Stainless Steel Exhaust w/Chrome Tailpipe Finisher
  • Double Wishbone Front Suspension w/Coil Springs
  • Multi-Link Rear Suspension w/Coil Springs
  • 4-Wheel Disc Brakes w/4-Wheel ABS, Front And Rear Vented Discs and Brake Assist
  • Electronic Stability Control (ESC)
  • ABS And Driveline Traction Control
  • Side Impact Beams
  • Dual Stage Driver And Passenger Seat-Mounted Side Airbags
  • Low Tire Pressure Warning
  • Dual Stage Driver And Passenger Front Airbags
  • Curtain 1st And 2nd Row Airbags
  • Airbag Occupancy Sensor
  • Outboard Front Lap And Shoulder Safety Belts -inc: Pretensioners
  • Back-Up Camera
Thread Starter #70
Kuwait, KL03
56. GAC Motor GA3 Sedan (GE)
  • Engine 4B16K1 1.6L (1598cc) L4 16V DOHC DCVVT
  • Peak Power (kW/rpm) 90/6300
  • Max. Torque (Nm/rpm) 153/4500
  • Transmission GETRAG 5-speed manual
  • Aisin Smooth-Shift 4-speed auto
  • Suspension Front MacPherson struts, independent
  • Suspension Rear Five-link, independent
  • Drivetrain Front engine, front-wheel drive
  • Brakes (front/rear) Vented disc/disc
  • Shark Fin Antenna
  • "Follow-me-home" Lights
  • Front Fog Lamps
  • LED High-mount Brake Light
  • Power Exterior Mirrors
  • Exterior Mirror Defrosters
  • Rear Window Defroster
  • Anti-pinch Power Sunroof
  • Intelligent Key
  • Cruise Control
  • Power Windows (Driver’s One-touch, Anti-pinch)
  • Power Door Locks
  • Anti-glare Interior Rearview Mirrors
  • Leather Seats
  • Leather Trimmed Steering Wheel
  • Power Driver’s Seat
  • Driver’s Lumbar Support
  • Trip Computer
  • Number of Speakers-6
  • Speed-sensing Volume Control
  • Radio, USB, AUX, CD player
  • GPS, Blue-tooth Connectivity
  • Telematics
  • Manual Air Conditioner
  • Auto Climate Control
  • Dual Front Airbags
  • Dual Front Side Airbags
  • Side Curtain Airbags
  • ABS+EBD, ESP, TCS, HBA, HHC, TPMS
  • Crash-sensing Door Locks
  • Front Row Seatbelt Pretensioners
  • Child-proof Door Locks
  • Electronic Anti-theft System
  • T-Box Surveillance System
  • Rearview Camera
  • Back-up Radar
Thread Starter #71
Kuwait, KL03
57. GMC Sierra Regular CAB 1500SLE 2016
  • 6-speed automatic transmission
  • Four upper cargo box tie-downs
  • 4.3L EcoTec3 V6 engine
  • CornerStep rear chrome bumper
  • Audio system, AM/FM stereo with 4.2" diagonal colour display, USB port and auxiliary jack
  • Outside heated power-adjustable, power-folding mirrors
  • 4-wheel antilock disc brakes
  • Chrome bodyside mouldings
  • Body coloured bodyside mouldings
  • EZ-Lift and Lower tailgate
  • Rear Vision Camera
  • Audio system, AM/FM/SiriusXM®/HD audio system with 8" Diagonal Colour Touch Screen with IntelliLink1®, USB2 ports and auxiliary jack
  • Cargo box LED lighting
  • Driver Information Centre with 4.2" diagonal colour display
  • 110-volt AC (3-prong) power outlet
  • Manual tilt and telescoping steering column
  • Trailering Package
Thread Starter #72
Kuwait, KL03
58. Acura MDX
  • Engine Type Direct Injection V-6
  • Displacement 3.5 liters
  • Valvetrain 24-valve, SOHC i-VTEC®
  • Horsepower @ rpm (SAE net) 290 @ 6200
  • Torque (lb-ft @ rpm) (SAE net) 267 @ 4700
  • Front-wheel drive with available Super Handling All-Wheel Drive™ (SH-AWD®)
  • Transmission 9-speed automatic transmission with Sequential SportShift paddle shifters and Grade Logic Control
  • Suspension 4-wheel independent MacPherson strut front / multi-link rear
  • Front Stabilizer Bar 24.0 mm: Front-wheel drive
  • 25.0 mm: SH-AWD Rear Stabilizer Bar
  • 25.4 mm: Front-wheel drive 26.5 mm: SH-AWD
  • Steering Electric Power-Assisted Rack-and-Pinion Steering (EPS)
Thread Starter #73
Kuwait, KL03
59. Infiniti Q70S
  • 330-hp 3.7-liter V6
  • 7-speed automatic transmission
  • Rear-wheel drive
  • Double-wishbone front and multi-link rear suspension
  • 10-way power heated front seats
  • Dual Zone Automatic Temperature Control
  • Infiniti Intelligent Key
  • RearView Monitor
  • 7-inch color info display
  • SiriusXM® Satellite Radio
  • 4-wheel Anti-lock Braking System (ABS)
  • Body colour exterior mirrors with LED turning signal
  • Heated, electrically adjustable and folding exterior mirrors
  • Front and rear bumper with Sport design
  • LED auto-level headlights and Daytime Running Light
  • Front LED fog lamps
  • LED rear lamps
  • Front windshield wiper deicer
  • Twin exhaust tailpipes with chrome finisher
  • Red “S” grade exterior badge
  • Wheel metallic paint
Thread Starter #74
Kuwait, KL03
60. Cheverolet TRAX LTZ 4x2 Auto 2016
  • Engine 1.8L4-Cylinder
  • Front Wheel Drive (4x2)
  • 140Hp@6200rpm Output
  • 178Nm@3800rpm
  • Transmission 6-Speed Automatic
  • Brakes 4-Wheel Antilock, front disc & rear drum
  • Air bags: front wheel and side-impact driver and front passenger dual stage side guard door beams.
  • Rear park assist
  • Theft deterrent System
  • Remote keyless entry with lock control
  • Power door locks
  • Leather seat trim
  • Front buck deluxe seating
  • Audio system , MyLink>AM/FM stereo with MP3, USB port Seek and scan
  • Sunroof
  • Single zone air-conditioning
Thread Starter #75
Kuwait, KL03
61. MG GS Turbo
  • Engine MGE 2.0TGI turbocharged, direct-injection petrol 2.0L (1995cc) DOHC L4 16V
  • –Peak Power (kW/rpm) 162/5000 -5300
  • –Max. Torque (Nm/rpm) 350/2500 -4000
  • Transmission TST 6-speed dual clutch
  • Suspension Rear Multi-link, independent
  • Drivetrain: front engine, front-wheel drive
  • Drivetrain: front engine, real-time four-wheel drive
  • Top Speed (km/h) 208
  • 0-100km/h Time (seconds) 7.89
  • Steering EPS
  • Automatic Head Lamps
  • Daytime Running Lights
  • Front Fog Lamps
  • Xenon Head Lamps with Washers
  • Heated Exterior Mirrors
  • Power Folding Outside Mirrors
  • Rear Window Wiper
  • Alloy Wheels
  • Power Sunroof
