kasargod/mangalore
Hello guys,
I am starting this new thread to discuss about any technical issues related to Suzuki Baleno. I am owner of Baleno Zeta Petrol and have driven 500 kms. I have 2 technical doubts with my baleno
1.Anti pinch power window for driver side. As demonstrated by Maruti, it is supposed to work if there's any obstacle. I kept my hand and windows dint stop rolling up. I touched the window and it still did not stop. Now I use force on window and then it goes down. I doubt it is the usual working of anti pinch driver window.
2 Baleno petrol doesn't get engine cover and heat insulation for exhaust outlet from engine which exposes the nearby wiring to high temperatures and I have noticed little melting of plastic covering of wiring.
Other than these 2 doubts/issues I am in love with my Baleno
NCR
Maruti Suzuki Baleno Technical Issues
1. Anti pinch window is supposed to prevent a pinch - i.e. when it will feel an obstruction at the last stage (of closing fully), only then it will stop automatically to prevent injury by the window glass. If you try this at the initial stage of rolling up, then it may not stop instantly as there is no chance of injury unless you reach the upper part of the window (near the metal frame). Some one correct me if I am wrong. I don't have this feature in any of my cars so I am not 100% sure.
2. As you had mentioned in the review, the melting was not too serious or was probably already there. Did you check on the current status of the melted part?
Members have also posted about unstable ride at high speeds. Even this may be an issue.
MODS - I think a duplicate thread was created by mistake. Please delete that one.
Re: Maruti Suzuki Baleno Technical Issues
I am not sure if this comes under technical issue
For me position of front arm rest is useless. It's fixed and I have to move my seat all way ahead as I am short driver.
kasargod/mangalore
It did not work even in last stage. Window would have crushed my fingers. It goes down only if I press the window down.
I find high speed stability really good. Today I touched 140 KMPH with 4 people and car was rock solid. I find suspension on stiffer side and not comfortable like my grand i10
But at high speeds it feels better
If you have to press the window down then there is a fault with the system. In my Rapid the window moves down as soon as it touches the obstacle at the last stage of closing. I do not have to do anything to move it down. It touches my hand, tries a bit to move (gentle push upward) and then moves down. Get it checked for sure.
kasargod/mangalore
Are you sure Anti pinch windows work only during terminal stage? I kept a cardboard and window did go down after pressing it against the door. I feel instead of anti pinch, window pinches you and goes down haha
I just verified anti pinch window is working as per design, window glass goes down at last stage of closing after hitting any obstacle.
pune
Hello guys,
what will be the ideal tyre pressure for my car? as m getting my new baleno on friday.
NCR
It will be mentioned in a sticker when you open the driver side door (the side/part where door locks). Congrats on the car. Get the pressures checked (and moved to ~30psi) as new cars are filled with more pressure during transit.
Hello folks,
I have took the delivery of my baleno silver delta petrol ! The car seems to be fine but the only one issue i faced with it is the dents ! There seems to be micro dents visible at an angle on the doors ! The dealership cars on display had them too ! But my car after 4-5 days started to show these small dents ! Like the ones on dzire and swifts!
NCR
Hello folks,
Do post some pictures. I don't think you are referring to actual (accidental) dents, but curves on the car body (design). Right?
