Still I will suggest against it. Below are some link which may be useful.
Some detail explanation has given.
HowStuffWorks "Why Fuel Additives Won't Improve Performance and Gas Mileage"
Do Those Fuel Additives Work? - Ask Our Experts Blog
Some extract:
To understand why so many of these additives are ineffective, it’s helpful to understand that all modern engines are controlled by the vehicle’s on-board computer. The computer relies on sensors to adjust engine functions, including fuel delivery, ignition timing and — on the most advanced engines — when the intake and exhaust valves open and close. Mileage-boosting fuel additives claim to increase the combustion efficiency of gasoline. But the automaker programs a vehicle’s computer to have optimal fuel economy with straight gasoline in the tank. Change the chemistry, and you may actually find a decrease in both performance and mpg — if there is any real change at all. Also, consider this: If there really were safe, cost-effective additives to increase fuel economy, wouldn’t some gasoline brands already be trying to sell them to you (along with their gas)?
Some More
There is no magical elixir that is designed to make your engine magically become more efficient and powerful. About the only time these additives may work is if you are not using the right octane rating fuel as your vehicle requires and you increase it to what it is supposed to be using an additive.
Amit, I get your point.. however I am only referring to additives which clean the system and not increase mileage (i.e over what the engine has been designed to give).
System cleaners do work and bring the engine back to the HP and Torque figure the manufacturer had mandated.
