]Why the dealer would sell the TD car,?
If new /upgraded model of same car is launched recently , then he has to discontinue previous TD ca r and provide new upgraded car for the TD, hence old TD car comes for sale , hence, possibility of getting a discontinued model is high ( early 2112 linea had poor GC).
Problems associated with buying a TD car.
New custemers will always take a full TD, obviously they won't shell out hard earned money without TD. As the 8 to 10 lac Rs car custemers are not going to be a first timers, hence they will put the TD car under proper test for suspension, GC at worst conditions leading to weak suspension s.
Also TD car will be revved to at least 3 to 4 k rpm, by the TD custemer, which will void the running in rules.
Running- in is a most important factor in the car's future,. Running -in allows the cars aluminium pistons, crank case , valves to gradually swell and acclimatise the hot engine conditions. If engine is revved at high rpm during running in , its parts will have mismatched dimensions, leading to permanent malfunction, low FE ,misfire, low power.It will require FREQUENT REPAIR WORK . For an individual custemer, it going to be headache , loss of peace of mind. Yes, cost of headache will be the discount qouted.
Car revved beyond the running-in limits are bound to change internal dimension of pistons, crank case, leading to gaps in between them.The gaps lead to leakage of fuel through them, leading to increased oil levels and reduction in viscosity of oil. This in turn leads to emission problems .
Don't ask him to remove the T D sticker , else unsuspecting buyer might buy it.
