**Disclaimer : This is a custom made project, has been tested under professional supervision and safety equipment. I'm not responsible if the product is handled improperly.**
A Dual Action polisher is a polishing machine that uses a circular motion combined with a spinning motion to create a rational double action. This motion is useful when polishing a surface by machine. The Dual Action polisher is famed for being easy to work with, making it ideal for beginners.
Read the original article at: What is a Dual Action polisher - DetailingWiki, the free wiki for detailers
Advantages of Orbital or DA polisher :
- There is virtually no risk of burning the paint because the pad never rests on one spot long enough for heat to build up.
- User friendly especially for beginners.
- Excellent for swirl removal, light polishing and waxing.
- Since there is not thermal buildup, paint texture will not be affected at all.
- Cost of equipment is relatively high especially for home use.
- Not effective for removing deep scratches.
- Many of us own an drilling machine at home, an attachment you be much more effective and reduce investment return of drilling machine.
- Since we generally own one or two cars and likely to wax or polish them once a month on average, it's hard to justify cost of a professional DA polisher. Especially to spouses or significant other or parents.
- Can also be used for polishing or waxing other surfaces as well. (Refer Standard material based polishing or waxing guidelines before starting)
- Easier to wax or polish compound curvature and reverse curvature surface since a drilling machine is comparatively small.
Yes i have tested it on 3 cars and 4 motorcycles and 1 scooter. All of the either had gloss finish or metallic finish, yet to try on a matte finish surface.
Cars : Verna 4S - silver - 2016, Ecosport - Smoke Grey - 2016 and Santro Xing - Maharaja Red
Motorcycles : FZ25 - Knight black - 2017, iSmart - Red - 2015, Duke 390 - Orange - 2019, FZ16 - Black - 2013.
Scooter : Honda Activa - White - 2018
Which wax & Polish was used ?
Meguiar's Mirror glaze High Tech Wax & Meguiar's Ultimate Polish
What are the specs of this product ?
- Orbital throw of 5mm.
- Weighty balanced.
- 5" Bosch Sanding plate.
- Black Oxide Coated (for orbital hub and rotar shaft).
- Can be used for clockwise and anticlockwise rotation without risking safety.
- Uses Bosch Sanding plate (velcro type) for easy replacement of polishing or waxing sponge or sanding pad.
- Since it's weight balanced unnecessary vibrations doesn't creep up.
[To Mods,
Sorry I had to make this thread via multiple replies/posts. I was getting problem when adding attachment of images since some had 4K resolution. Feel free to make changes if necessary]
