The short video first shows the IQ Light, an optional extra for the new Amarok, integrating active full beam dipping and cornering lights. The video then pans out to reveal a full (albeit shadowy) outline of the upcoming 2022 Amarok.It looks like the new Amarok won’t deviate too much from the original when it comes to the styling; the grille will incorporate the VW logo, albeit in a slightly slimmer form. We can also see a grab handle in the truck’s load bay.
Previous spy images have also revealed it’ll feature a set of side steps, along with a distinctive two-tone rear bumper and ‘Amarok’ script pressed into the tailgate.
VW’s new workhorse will share its underpinnings with the next-generation Ford Ranger. The Amarok is one of a number of new, jointly developed commercial vehicles as part of a tie-up between the two brands that will see pick-ups, vans and some van-based passenger cars revealed over the coming years. The overall silhouette of the Amarok is a clear indication of the two pick-up trucks sharing the same platform.
The Amarok will be larger than its predecessor, 100mm longer with a total body length of 5,350mm. However, the wheelbase grows even more, by 175mm to 3,270mm. VW says that this results in substantially more room in the cabin for passengers, while the shorter overhangs mean it is more capable off-road than before. Total payload increases to 1.2 tonnes, while more engine and gearbox variants will be capable of achieving a 3.5-tonne braked towing capacity.
An interior sketch gives us a glimpse at the pick-up’s interior, revealing a completely new dashboard design that features Volkswagen’s latest steering wheel and its newest “Virtual Cockpit” digital instruments. A new central infotainment system also features, and it appears the brand will retain some physical switchgear, unlike in some of its latest passenger models.
Volkswagen describes its Ford Ranger rival as having “a completely new appearance inside and out” and “even more extensive equipment on board”, including “significantly more driver-assistance systems” and new connectivity features. The company also claims it will feature “innovations that have not been seen before in this segment.”
Technical details for the Amarok are still thin on the ground, but VW has confirmed that the pick-up will be powered by a turbocharged V6 diesel engine. Its chassis sibling, the Ford Ranger, features a 3.0-litre unit, and it’s all but certain that the same powertrain will be used in the Amarok.
Like the Ford, the engine should be linked to a 10-speed automatic gearbox and a new permanent four-wheel-drive system, which promises to make the new Amarok faster and much more capable than the previous-generation model.
Entry-level versions of the Amarok will likely be powered by one of Ford’s turbocharged 2.0-litre diesel units. The new Ranger is already offered with updated versions of the previous model’s four-cylinder units – and there’s little chance that Volkswagen would re-engineer the platform to suit its own four-cylinder diesels, because the cost would be prohibitive.
There are plans for further expansion, so it’s likely that Volkswagen will follow in Ford’s footsteps and launch a pure-electric flagship version of the Amarok. Lars Menge, Volkswagen Commercial Vehicles product marketing boss, said: “In terms of drive system we are continuing to use highly efficient TDI diesel engines for the new Amarok.
Autoexpress
