Dear Experts, I am using Baleno RS and a couple of months ago it got its 4th servicing done. Just after that I am facing road noise at high speed, also bit louder road noise on rough roads. Here I must mention that I have installed two cameras on the ORVMs and door panels were also refitted. All exhaust system was disassembled and reassembled to find out the source of another noise (which they could not do !) One plastic panel was also removed/reinstalled from the end of the steering column. tires are the same Yokohama Earth 1 205/16 just rotated it.
So is it possible to identify the source of the road noise:
1. through the ORVMs ? (although that has been tightened by mseal)
2. through the inside of the doors ?
3. through the weather seal of the doors ?
4. through any open space inside the car, below the steering column ?
5. Anyway from the boot ?
6. through any space under the dashboard ?
7. whether the exhaust system is the culprit ?
Earlier it was very quite but now every thing has changed. Is it possible to know the actual source of that noise ? If so please let me know, if it is not possible by self, in that case I may/will get help from SS. Your expert opinion is desperately needed.
