I am pleased to see the global bike manufacturers showing their interests in the premium segment too. As far as the Kawasaki Z750R is concerned, I find the new design eye-catching.
Here are the technical specifications of this bike.
Engine
Engine type: 4 cylinders, 4-stroke, Inline
Displacement: 748 cc (45.7 cubic inches)
Bore × stroke: 68.4 mm × 50.9 mm
Cooling system: Water cooled
Power: 106.05 HP (78 kW) @ 10500 rpm
Torque: 78 Nm (7.95 kg-m) @ 8300 rpm
Throttle: Cable operated
Valve train: DOHC, variable
Valves/cylinder: 4
Fuel and ignition
Sparks/cylinder: 1
Fuel supply system: Fuel injection
Ignition type: Digital CDI
Funnel diameter: 32 mm
Compression: 11.3:1
Engine mounting: Transverse
Gear box: Manual 6-speed
Image Source: www.kawasaki.co.uk
