Hyundai i20 Sports (2011) AC Control Gauge Not Working
Gurgaon
Hello Team,
I own an i20 sports 2011. I am facing an issue with the temp control gauge. (when rotated only increase the temperature on both sides) I visited service center & as per them complete climate control assembly needs to be changed. (Cost 24k).
Can someone suggest if any repair can be done or should i get it replaced only.
Thanks & Regards,
Amit
Gurgaon
Hello,
Its an automatic AC but the knob with which I can set the temperature is not working. It has set itself to high temperature & I am not able to lower the temperature. My query is if this knob can be repaired or replaced rather than changing the complete AC control kit.
Regards,
Amit
Shillong
Hello,
Regards,
Amit
Have you found the solutions or did you just replace the whole assembly?
allhyundaicars
I didnt see the OP's message.
@Ding - you have to buy the full part which costs 4k. You can get a used one too if you look in the market.
You can check boodmo application and check the parts yourself.
