Hello fellow petrol heads
On the 3rd of October 2021, while driving back to Bangalore from Tumkur on my 2016 Creta, I noticed a sudden change in cabin temperature. The air conditioning had suddenly cut off and wasn’t cooling at all anymore. With the many weather changes in Bangalore since the last few weeks and the many dug up roads, driving without A/C is almost an impossible task (at least for me). After reaching Bangalore rather uncomfortably (without a/c of course), I drove up to Trident Hyundai at Kalyan Nagar which has been my long term HASS. The service advisor there inspected the car well and told me the compressor wasn’t turning on. To my bad luck, the extended warranty of my car had expired so replacing the compressor assembly would be a complete shell out from my pocket. The service advisor told me the part was not available in stock and also advised me to try aftermarket options which could be cheaper. I took his advice and drove to Aditya Car A/C in Koramangala which has been my long term A/C repair store for my Santro. Their prices were always on the higher side but the workmanship has been excellent and even after 15 years, the Santro’s A/C cools better than expected.
Upon arrival, the proprietor Mr. Pradeep and his team inspected the car well and told me that the compressor was jammed and had failed from regular wear and tear and had mentioned that there was no leakage of refrigerant. He also disassembled the bumper to check the condenser and said that the condenser was blocked with a lot of dirt and grime which ultimately led to the compressor failing. He advised me to replace the compressor and condenser, flush out the entire system of all the grime and refill gas for the system. He quoted ₹33k but with a bit of bargaining, settled it at ₹31k. The quoted price was definitely higher by at least ₹3k than most places but knowing the workmanship of his staff, I decided to get it fixed with him itself. He promised a warranty on the compressor and sourced the original Hyundai Hanon compressor. He completed the job in about an hour and while his staff were working on the car, he mentioned to me that the AC compressor failing after 4 years wasn’t an uncommon sight and that he had replaced the compressor for an elite i20 the same morning as I got my car fixed. Apparently, that car was also a 2016 model and had the same 1.4 CRDi Diesel engine as my car. This brings me to ask a few questions to fellow forum members and I would really appreciate it if someone could shed light on this matter
1. Have any other Hyundai owners faced the issue of AC compressors failing this early?
2. Is this a common issue with all HMIL models made in 2016, or just exclusive to the 1.4 CRDi engine?
3. Would this repair on my car have been significantly cheaper anywhere else?
Enclosed a copy of the invoice
