Hope i am not so late
There are 2 types , one to be heard outside too ,
one to be heard inside alone. sql and spl respectively.
Each one is to be designed in separate ways
And there is nothing called original grey.
Original is white piece , with mrp tags and importer's tag , sahil international in jbl
Other is grey , which is without the tag.
Both are produced same ways , a white has manufacturer warrenty and grey may have seller warrenty
For a budget of 10K , the specification is very limited kinda
Go for a 2 channel amp from jbl
And boxed subwoofer from jbl
JBL GT5-1204BR
forget its mrp , bargain around 5.
Do not use 4 channel for a sub woofer.
use a mono ELSE 2 channel
Using mono will not be in your budget. Also you do not have powerful head unit.
Use good wiring kit , also from jbl , as i think this ine exceeds your budget slightly , other cables will increase so much!
Hope i have given you a good idea for a 10 K budget set up!
JBL GT5-1204BR
