nice, check out this one.Yamaha FZ1 is one of the purest forms of performance. Yamaha FZ1 is a high performance sport bike of FZ series along with helmets
. People all-around the world have given good response to Yamaha FZ series. Yamaha FZ1 is simply born to rule the streets. It is available in ABS too.
It features racial, mighty and superior 998cc super sport-based engine. It has got fearless, muscular, bold and stunning looks. It is priced at US $ 10290.It is a brutal performer and defines new dimensions of performance. It generates the maximum power of 110.3 kW @11,000 RPM and maximum torque at 106Nm @ 8,000 RPM. It has serious street attitude, the spirit of racing and attachment for saddlebags. The ECU mapping has been improved to enhance the throttle response for its 2010 version.
Its features are as explained below:
Features:
Engine and transmission:
Displacement: 998cc
Engine type: In-line four, four-stroke, liquid-cooled
Compression ratio: 11.5:1
Bore x stroke: 77.0 x 53.6 mm
Power: 110.3 kW @11,000 RPM
Torque: 106Nm @ 8,000
Valves per cylinder: 5
Fuel system: Injection
Ignition: Digital TCI: Transistor Controlled Ignition with 32-bit ECU
Gearbox: 6-speed
Final drive: Chain
Dimensions:
Seat height: 815 mm
Height: 1,204 mm
Length: 2,141 mm
Width: 770 mm
Ground clearance: 140 mm
Wheelbase: 1,461 mm
Brakes and wheels:
Rake: 25.0°
Front suspension: 43mm fork
Front suspension travel: 130 mm
Rear suspension: Single shock
Rear suspension travel: 130 mm
Tires:
Front: 120/70-ZR17
Rear: 190/50-ZR17
Brakes:
Front: Double disc
Rear: Single disc
Front brakes diameter: 320 mm
Rear brakes diameter: 245 mm
Physical capacities:
Gross weight: 220.9 kg
Fuel capacity: 18.01 L
Color: Raven, Candy red
The die-cast aluminum frame that is identical to super-sport bike. It has large radiators that enhance the cooling of the engine. It has a powerful disc braking system that is magnificently strong. It is also available in ABS version that has even more stopping power. The FZ1 offers thrilling and fierce performance. Its fuel consumption is 14.9 km/l. Carbon dioxide emission is 155.9 CO2 g/km.
Amazing bike to purchase!
Features:
Displacement: 998cc
Gearbox: 6-speed
Final drive: Chain
Dimensions:
Seat height: 815 mm
Height: 1,204 mm
Length: 2,141 mm
Width: 770 mm
Wheelbase: 1,461 mm
Brakes and wheels:
Rake: 25.0°
Tires:
Front: 120/70-ZR17
Rear: 190/50-ZR17
Brakes:
Front: Double disc
Rear: Single disc
