Why Cars Does Not Have Vacuum Pressure Release Lever?
God 's Own Country
i have seen a pressure release lever in buses for vaccum release i suppose which the driver presses to remove vaccum pressure accumulated on vehicle stoppage, why this system is not present in cars which have vaccum assisted brakes
Re: vaccumpressure release lever in bus/trucks absent in cars
It is for the air brakes. cars done have air brakes, they use hydraulic brakes.
God 's Own Country
but dont newr cars use vaccum assist along with hydraulics for braking thats why once u switch off the engine braking efficiency decreases so u have to pump the brakes my question is how vaccum pressure is controlled in cars unlike release valves in buses
Dude, what you find in trucks and bus is not vacuum release.
That is releasing the compressed air from the spring loaded brake chamber, which in turn engages the parking brake by spring load.
cars use hydraulic brake system (vaccum assisted but that is different , read only system)
Trucks/bus use air brake system.
what you find as brake oil is air in truck and bus.
you have brake oil reservoir.
truck have air tank.
air is filled by a compressor run on engine power.
only during running high pressure is needed and it self release the excessive air .
during stopping/parking that is done by the driver. its not advisable for the air tank to be in high pressure during parking
ilango[speed thirst];74576 said:
...........during stopping/parking that is done by the driver. its not advisable for the air tank to be in high pressure during parking
Small correction ilango. It is not that driver is releasing the compressed air from reservoir during parking. Air in the reservoir / tank remains on it in the same pressure (no harm in maintaining high pressure, the system is designed to withstand the pressure) but the air from brake chambers are released so that the spring loaded parking brake will be engaged (Parking brakes cannot be disengaged without air pressure). Will try to post some pics to explain the same.
God 's Own Country
so is airbrake more powerful than hydraulic brakes and which is safer
what are power brakes as mentioned in stickers on some cars
Both holds their own advantages and disadvantages.
For example, Response time in Air Brake is very less compared to Hydraulic brakes, but the system requires a compressor for pressurised air, reservoirs to store them, which indeed increases the no. of components and weight.
IMO air brakes are highly responsive, efficient & safer than hydraulic brakes.
No clear idea bout Power Brakes. I have seen such stickers in Ambassador Cars, AFAIK they are with some after market bigger brake boosters (vacuum assisted)
