Which are Best Rear Speakers for Ford Figo?
thrissur
pioneer TS-A934H
Size 16cm x 24 cm
Max. Music Power (Nominal) 500 W (80 W)
Frequency Response 27 Hz to 27 kHz
Sensitivity (1 W/1 m) 91 dB
Impedance 4 Ω
Mounting Depth 84 mm
Cut-Out Dimensions 153 mm x 222 mm
ROCKFORD FOSGATE Prime Speakers (R1693)
Power Handling60 Watts RMS
120 Watts MAX
Configuration3-Way Full-Range
Tweeter Diameter0.5"Tweeter Depthn/a
Frequency Response48Hz - 22kHz
CrossoverTweeter High-Pass (HP): 6dB
Sensitivity(1 watt/1 meter)89dB
Grilles IncludedYes
Mounting HardwareYes
JBL GTO 949
DESCRIPTION 6"X9" 3 WAY COAXIAL SPEAKER
POWER HANDLING ,RMS 100W
POWER HANDLING PEAK 400W
FREQUENCY RESPONSE 45HZ-21KHZ
SENSITIVITY (2.83V/M) 94DB
IMPEDANCE 2 OHMS
MY HEADUNIT IS PIONEER DEH 3490..NO AMP YET ..BUT LATER IM PLANNING TO ADD 4 CHANNEL AMP JBL 646 or kenwood 846 ..PLS HELP ME
Recently for a Ritz Vdi we fitted JBL GTO949 and for that we do need a wooden plank that will replace the rear parcel tray. This is a oval speaker that has a size of 6" x 9". For the front we used 5" component speakers from JBL I am not sure about the model. We fitted a Sony CDX-GT44U as the player. We got all this fitted at Reliance Autozone in Double road Bangalore. There was an 50% off on some products like the component speakers. We also fitted a Autocop for which we got a 50% off and costed somewhere around 2000. The total music system came to around 13000k. [:)]
We are going for a same setup for a friend's new Ritz Vdi thats on the way. [:D]
thrissur
thank u for all rplys..at last im stuck with jbl gto 649 for rear speaker..i didint find ny thing ffor the front speaker..now im adding 4 channel amp of jbl 800w.with rockford Fosgate P1L-1X12 150w rms and 300w max..how to connect them both rear speaker and sub???
Guys check out Rainbow, Flux, Bull compos.
There are many good brands too but others are offering only high end.
But Rainbow, Flux, Bull has good compos in budget too.
