Using Distilled Water To Clean Windshield?
Thread Starter #16
Bokaro/Bangalore
I just bought one litre of Distilled water (Rs. 18) from shell petrol bunk.
Just confused what to mix it with, Shampoo (i read good review about it) or Colin??
Not Shampoo, unless you plan to wash the car immediately after every spray.
The accumulation at the base of your wind-shield on the cowl will smell after some time.
Colin is good.
Even dish-washing liquids, mild, are OK.
Ooh. Good question. [thinking]
I am not sure how much the typical bottle of colin measures, but I pour about 1/4 each time into an empty washer tank, and the capacity of the washer tank in the Fabia is just about 2 litres.
I find I get a good result with that.
The problem with the Fabia is that the spray nozzle is very fine, and the pump pressures I think are higher, so if I put in a more stronger solution, the result is very sudsy.
MH 10
somewhere i read that
Honda uses specially made windscreen washer fluid for there cars which contains 100% detergent like material which they top up at regular service intervals & don't recommends 100% water as it create scaling in nozzles & reservoir tank & hampers windscreen washer pump
what about skoda?
Hmmm this is new to me , can any Honda vehicle owners confirm this , especially Archit and Akash??
And Skoda can be confirmed by Aditya?
About what vvk1987 has told, i cant surely commment on that. Windshield washer fluid is somewhat soapy just like Colin,even smells the same. They usually top it up while service.
For Alto i use Colin.
MH 01 / MH 43
Okey guyz. I top-up my DZire's wiper tank every week. Once in a month I put one packet Shampoo (the Rs2 or 3 one) mixed in water. No side effects till now works great than using only normal water you get some liquid in some car accessories shop. I remember I got some liquid long back with a set of wiper blades I bought for my Indigo long long back the brand was Syndicate donno if we get now also.
what about skoda?
Most A.S.S will put in a washer detergent if the service is in the "Good" range.
And re scaling, that normally happens because of hard water (calcium salts etc in the water) and I suspect the addition of detergent would not help. All you can do to prevent that would be to use distilled water, which is how I suspect this thread got started!!
Guys,
AFAIK, distill water available in petrol bunks is for the batteries. (they contain very small amount of acid to assist charging).
NOT TO BE USED FOR WINDSHIELDS.
Hard water not to be used for windshields as they leave peculiar marks on the glass.
Packaged drinking water or normal clean soft water may be used with shampoo mixed for windshields.
In my experience, you can use Shampoo with water for quick cleaning of the windshield if its dirty. But it doesn't yield very good results when used in the windshield tank. I would rather suggest you to buy wind shield washer which is anyways not too expensive.
This is how I take care of my windshields:
1. While washing, first wash the roof and let the dirt flow down
2. Wash the windshield with separate clean cloth
3. Wipe of excess water the windshield with clean cloth and while still wet, use a news paper (poorer the quality the better, since they have higher affinity for water)
4. For windshield: Currently using SONAR brand with very diluted form
At times, I have used Colin too to clean the windshields - but when you are using news paper technique Colin is seldom required.
sethumurugan
This is what I do.
  • I generally wash my car once in a week.
  • As soon as was is over, I open up Windshield reservoir tank and top up with ordinary water (metro water) till the neck of the tank. Spark's reservoir tank has long neck.
  • Take small amount of water in mug.
  • Mix Rs.1 (or Rs.3) shampoo and dilute it till it got dissolved in water and become soapy water.
  • Fill the gap in reservoir tank.
That is it. This is what am doing from 2008 (from my M800 days) and never faced any problem.
Where friends are
Basically hard water should not be used because salts in the water may get crystallized & deposited in tiny opening of windshield washer nozzles ( I reside in hard water area, & we have highest incidence of urinary stones, bathroom accessories need services 3-6 monthly) & thereby 1) misdirect the jet or poor jet (when partial deposit) 2) complete block the jet 3) latter might hampers windscreen washer pump, 4) deposit in tank might damage the tank, 5) salt accelerates rusting over metal parts.
