The Two Wheelers Recall Thread
Triumph Motorcycles has issued a recall for about 3,700 units in USA with regards to a potential front brake issue on these motorcycles. The models affected by the recall are the entire Tiger 1200 range (2018-2020), Speed Triple S (2018-2020), Speed Triple RS (2018-2020) and the Street Triple RS (2018-2020). All the motorcycles in question run Brembo brakes up front. The National Highway and Traffic Safety Administration (NHTSA) detected a potential manufacturing defect for the brakes on these models. The brakes might have a higher concentration of Nickel. This results in more salt and water absorption on the back plate. And excess salt and water absorption could lead the brake pads to corrode at a higher rate than normal, especially in winter and rainy conditions. There is a risk of the brake pad friction material coming off the backing plate.
Read:
Brembo Issues Global Recall For Certain Brake Pads
Italian brake original equipment manufacturer (OEM) Brembo has issued a global recall related to OEM motorcycle brake pads fitted to a number of different bikes, from different makes and models. The recall relates to the BRM10B compound and the amount of nickel used in the brake pad's construction. The amount of nickel in the pads can potentially lead to the compound becoming porous, allowing moisture and humidity to affect the performance of the pads. The build up of moisture can cause corrosion, which in some cases can cause the friction material to detach from the brake mounting plate, causing serious brake failure.
Read:
Ducati 1299 Superleggera Recalled In The US
The exclusive Ducati 1299 Superleggera, which was produced in limited units, has been recalled in the US. According to recall information posted by the National Highway Traffic Safety Administration (NHTSA), the recall pertains to all 97 bikes that were sold in the US. The recall seems to have been issued, as a result of an issue with the brake pads, which may see the brake pad's friction material detaching from the brake pad's back plate. This can happen specifically, but not exclusively, for motorcycles that have been operated in corrosive environments.
Read:
The motorcycles that fall under this recall drive include the Interceptor 650, Continental GT 650 and Himalayan, which are three of its latest motorcycles. The voluntarily recall has been issued after the company found out a brake calliper corrosion-related issue in models sold in these countries (Europe and to South Korea).
On further investigating the issue, it came to light that the brake calliper is prone to corrosion on being subjected to sustained, long term exposure to usage on roads that have been treated with a certain combination of salts to prevent the formation of ice during the winter season.
This corrosion is known to damage the brake calliper piston bore and assemblies, which, in turn, leads to unusual braking sound, higher brake drag and even reduced braking efficiency. Also, it is worth a mention here that even though the issue is known to have affected only a few motorcycles, the company prefers replacing the part as a proactive, safety-related service action.
Read:
Honda has announced a recall for the Honda CBR1000RR-R Fireblade in select markets of Europe for a potential con-rod issue. The notice said that 300 motorcycles have been recalled and the recall process is precautionary. The connecting rods in the affected motorcycles could have a metallurgical defect, which originated at the company's connecting rod supplier's facility. The supplier may have manufactured a faulty batch of con-rods. Honda said that so far, no motorcycle among the affected units has had a breakdown. The deliveries of the motorcycle will need to be stopped temporarily as well. As of now, the recall pertains to motorcycles sold only in Europe.
Read:
Kawasaki Ninja ZX-10R recalled in the US
Kawasaki USA has issued a recall on certain motorcycles of 2019 and 2020 Kawasaki Ninja ZX-10R due to an apparent programming error in the engine control unit (ECU). The error could cause the engine to backfire when the rider uses the quickshifter at high rpms. According to the defect notice published by the National Highway Transportation Safety Administration (NHTSA), as many as 1,529 motorcycles will be affected by this recall. The models include 2019-2020 Kawasaki Ninja ZX-10R, 2019-2020 Kawasaki Ninja ZX-10R ABS and 2019-2020 Kawasaki Ninja ZX-10RT ABS KRT Edition.
Read:
BMW Motorrad Recalls Popular Models In Europe
BMW Motorrad has recalled as many as 440 affected bikes in Europe, across several models, including the BMW R 1250 GS, BMW R nine T, BMW R 1250 RT, BMW R 1250 R, BMW R 1250 R, BMW K 1600 GT and BMW K 1600 B. The bikes affected by the recall were produced worldwide between October 31, 2019 and January 30, 2020. According to the Federation of European Motorcyclists' Association, the type of alert has been listed as 'products with serious risks'. The issue is apparently with a manufacturing problem with the rear axle of the affected bikes.
Read:
Husqvarna Svartpilen 701 And Vitpilen 701 Recalled Globally
Husqvarna has issued a global recall for its Svartpilen 701 and Vitpilen 701 motorcycles over a potential fuel leakage problem. All Husqvarna Svartpilen 701 models manufactured in 2019 and 2020 have been recalled along with all Vitpilen 701 motorcycles manufactured between 2018 and 2020. The total number of models affected isn't known yet. In a statement, Husqvarna said that the fuel in the motorcycle may leak from the area where the fuel level sensor is placed or the fuel pump mounting area.
The problem is caused by 'unevenness in the area of the sealing surface between the tank and the fuel pump as well as the tank and the fuel level sensor'. The company will be contacting the owners of affected motorcycles via letters and fix an appointment with the nearest Husqvarna dealership. All affected motorcycles will get a new fuel tank with thicker walls and a new sealing system. The inspection and replacement will be done free of cost for all customers.
Read:
Triumph Tiger 900 Recalled In USA Over Faulty Reflex Reflectors
Triumph Motorcycles America has issued a recall for 603 units of the Triumph Tiger 900. The cause of recall is a potentially faulty reflex reflector. The National Highway Transport Safety Administration (NHTSA) has published documents which say that only two per cent of the 603 recalled vehicles could have a faulty rear reflex reflector, which could possibly detach from the motorcycle due to wrong size of spigots. While it may not present immediate danger to the rider, but if the reflex reflector is missing then it doesn't meet USA's Federal Motor Vehicle Safety Standards (FMVSS).
Read
BMW Recalls Over 16,000 Motorcycles In The US
BMW Motorrad has issued a recall for motorcycles manufactured between 2005-2012 in the US over a fuel pump issue. The fuel pump issue affects BMW R 1200 GS and other non-GS models, according to a recall issued by the US National Highway Traffic Safety Administration (NHTSA). The recall states that "motorcycles involved previously received a support ring repair under a 2014 recall number 13V-617, which also dealt with a potential leak at the fuel pump. Vehicles that received the earlier recall remedy, which did not have a fuel pump replacement at a later date, may have a fuel pump flange that cracks and possibly leaks over time."
Read
BMW R 1250 Models Recalled In The US
BMW Motorrad has issued a recall on several models of the 2021 R 1250 range due to an issue with a tyre pressure label. According to a recall report filed by the National Highway Traffic Safety Administration, on 2021 BMW R 1250 models, the material used in the tyre pressure label could cause the sticker to detach from the motorcycles' frame. And in case, the sticker detaches and falls off, and be absent from the motorcycle, the vehicle will not conform to the Federal Motor Vehicle Safety Standards (FMVSS) any more.
Read
Royal Enfield has identified a defect in Ignition Coil of its certain motorbikes that can cause misfiring, reduced performance and in rare cases, an electric short circuit.
Therefore, the company has recalled 2,36,966 units of Classic, Bullet (Jan 21 - Apr 21) and Meteor (Dec 20 - Apr 21). Quoting official statement below.​
Royal Enfield has discovered a defect in one of the parts used across some of the motorcycle models that we manufacture and sell. The defect is in the ignition coil that can cause misfiring, reduced vehicle performance and in rare cases, an electric short circuit.
The defect was discovered during routine internal testing and the issue has been clearly identified and isolated to specific batches of material sourced from our external supplier between December 2020 and April 2021. While the issue is rare and does not impact all motorcycles manufactured during the above mentioned period, in keeping with safety regulations and as a precautionary measure, Royal Enfield has decided to undertake a proactive, company-initiated recall of select motorcycles models produced in the above mentioned time period.
The company will be calling in close to 2,36,966 motorcycles of the Classic, Bullet and Meteor models. Of these, the company will call in Meteor motorcycles manufactured and sold between December 2020 and April 2021, and the Classic and Bullet manufactured and sold between January and April 2021. These motorcycles will undergo inspection and replacement of the said defective part, if required. We estimate that less than 10% of these motorcycles will require replacement of the part.
This proactive recall action will be applicable to Meteor, Classic and Bullet model motorcycles sold in India, Thailand, Indonesia, Philippines, Australia & New Zealand and Malaysia between respective time periods mentioned above.Royal Enfield service teams, and/or local dealerships will reach out to consumers whose motorcycle Vehicle Identification Number (VIN) number falls within the manufacturing period mentioned above. Consumers can also proactively reach out to their local Royal Enfield Workshops, or call Royal Enfield on 1800 210 007 to verify.
We would like to reiterate that we have very stringent sourcing protocols and that all our motorcycles are rigorously tested to global validation standards of quality and durability. The safety of our riders is of prime importance to us at Royal Enfield and we are deeply committed to the duty of care to all our customers. We are committed to swiftly implement the recall action, and customers will be proactively contacted through respective local dealerships.
Thread Starter #13
Over 28,500 Honda Motorcycles Recalled In USA Over Faulty Rear Reflector Fitment
American Honda Motor Co. has issued a recall for 28,528 motorcycles in USA over a faulty rear reflector fitment. The recall notice by the National Highway Traffic Safety Administration (NHTSA) says that, a dim rear reflector may reduce the visibility of the motorcycle to other drivers, increasing the risk of a crash or injury. The potentially affected motorcycles were manufactured in 2020-21 and the units that were recalled belonged to 13 model ranges. After a compliance test by Korean motor vehicle authorities on a sampling of rear reflectors in December 2020, Honda Korea was informed that the rear reflectors of a Korean market vehicle were non-compliant. Honda investigated the affected population and whether the affected models were out of compliance under other countries' regulations between January and March 2021.
Read
Thread Starter #14
Honda Motorcycle And Scooter India Recall Multiple Models In India Over Reflector Issue
Honda Motorcycle and Scooter India (HMSI) has issued a recall for multiple models in India owing to a potential issue with the reflex reflectors. The model which are affected by the recall are the Honda Activa 5G, Honda Activa 6G, Honda Activa 125, CB Shine, Hornet 2.0, X-Blade, H'Ness CB 350 and the CB 300R. The total number of units recalled is not known yet. The safety reflector on the affected models is placed at the fork and has slight variations from the required photometric provision. This results in insufficient light reflection which may lead to lesser visibility especially in the dark. However, Honda maintains that impact on vehicle visibility is insignificant. The affected Honda models were manufactured between November 2019 and January 2021.
Source
Thread Starter #15
Royal Enfield recalls 2021 Classic 350 for Brake Reaction Bracket Issue
Royal Enfield has recalled the 2021 Classic 350 for the brake reaction bracket issue. Motorcycles equipped with single-channel ABS and rear drum brake variants are facing this issue. Classic 350’s manufactured between September 1, 2021 and December 5, 2021 have defected with the issue. Around 26,300 units will be recalled.
Read
