Technical Automotive DIY Video Guides
Rastatt, Germany
the video gives you a step by step tutorial how to adjust the valve clearance of a Peugeot / Citroen TU3 JP engine with 1.4 l. This engine is used in many models of Peugeot and Citroen:
Peugeot / Citroen Adjusting valves 1.4l TU3 JP engine - YouTube
The video has a German soundtrack, but English subtitles are added to YouTube. If you don't see them by default, watch the video directly at YouTube and press the subtitle button below the frame.
Enjoy it,
Jürgen
Rastatt, Germany
Video: Replacing the cylinder head gasket
the video gives you a step by step tutorial how to replace the cylinder gasket of at your Peugeot with the 1.4l TU3 JP engine. A broken head gasket is a rather typical failure of this engine. Most times you'll find cooling liquid in the oil, oil in the cooling liquid, or the engine is loosing oil a the right front side:
Peugeot / Citroen Replacing cylinder head gasket 1.4l TU3 JP engine - YouTube
The video has a German soundtrack but English subtitles are available at YouTube. If you don't see them by default, watch the video directly at YouTube and press the subtitle button below the frame.
Enjoy it,
Jürgen
Rastatt, Germany
Video: Replacing a ball bearing
the video gives you a tutorial how to replace the ball bearing in an idler. This is necessary when the spare part isn't available anymore, i.e. for classic cars, or when the price of the idler is much higher than the price of the bearing:
http://www.youtube.com/watch?v=ZKuPWyN7kQM
The video has a german soundtrack but English subtitles are available at YouTube. If you don't see them by default, watch the video directly at YouTube und press the subtitle button below the frame.
Enjoy it,
Jürgen
