re: Tata's New Family of 1.2L 3cylinder petrol engines-Revotron a stop gap!
Revotron is a family of turbo charged petrol engines. 1.2T the first one. Check the spelling also. There is no comment from TML that the engine capacities will be 1.2 L always. Also no clarification that it will be always 3-cylinders. Nexon concept featured a 3 cyl Revotron 1.2L,I believe. That's all.
Everybody knows the current engine is a derivative of Xeta block. Next engines under the branding will be aluminium block.
I think this is what the thread starter tried to express..
Revotron first step towards more Tata petrols | Car News | Entry level saloons | Autocar India
Compared to motors like Ford’s 1.0-litre EcoBoost and VW’s TSI which sport direct-injection and multi-valve heads, the cast-iron block, two-valve per cylinder Revotron seems relatively low-tech. However, Leverton believes that for a first step, this is the right approach, keeping the cost base in mind as well. “This engine is a straightforward and reliable approach, keeping in mind cost of ownership. When you have a turbocharger, you don’t necessarily need more valves. We’ve done a lot of work to reduce friction and designed an all-new head to optimise forced induction. The block too is completely re-designed for lower weight and more rigidity. So I think there is integrity in the configuration.”
However, Leverton hinted that a hotter Revotron, which is higher-revving and has more power, could be the next step. According to sources, the next step could be a 100-plus-bhp motor with a bigger turbo, more sophisticated electronics and an all-new four-valve head.
The big news is that Tata is working on an all-new engine family with three- and four-cylinder configurations. Unlike the Revotron, which has its roots in the Tata Xeta motor, this family of all-aluminium engines will be developed from a clean sheet of paper.
A 1.2-litre, three-cylinder will be the main configuration to power Tata’s range of future small cars. A 1.5-litre four-cylinder petrol is also on the cards for bigger sedans and SUVs.
The Revotron engine impressed us with its refinement, but Tata Motors insiders say that the new family of engines will be even smoother. According to sources, the all-new engine family will use hydraulic lash adjusters and roller finger followers for mechanical noise reduction.
One last thing. @AMG From where did you got the mileage figure which is not yet published by the company and reserved till the time of launch
The power is up to 89 bhp for the final car. The one quoted by you is of the engine showcased in Feb 3.!!
