Skoda Octavia Needs a Tyre Change
chennai
Hello everyone,
My Octavia has Goodyear NCT 195 65 r 15 , 2 of the tyres are completely worn out.
So what should i do now. I want to increase the width to 205 and change the brand too. But is it worth doing?
Options available.
->change 2 tyres (stock size)
-> change all four to 205 65(more ground clearance )
-> change all four to 205 60(better performance but less clearance)
-> change rims to 16 and put on 205 65 (its costly , but both performance and clearance)
-> Brand: Michelin , bridgestone or yokohama?
I need your suggestions
Jeno[cheers]
Re: Octavia needs a Tyre change
The 195 tyres are sufficient for the Octy and provide enough grip. I dont recommend you going for R16 ones as they will affect the ride quality considering our roads. Go for the 195 R15 tyres again. Michelin would be better.
205 60 R15 without any change to the wheel rims would be the best upgrade in my opinion. It would not be worth an upgrade to R16 wheel rims, as the suspension & steering dynamics would not support + clearance issues. Brand- Michelin, Continental, Goodyear- all are equally good
Hey buddy first go through this Tyre size calculator and choose a wise section which does not have any impact on the speedo readings. Here is the link:Tire size calculator
If you have the budget i would say change all four tyres and then follow tyre rotation every 10k KMS atleast so that you don't face this issue in the future.
Brand , avoid Bridgestone they are a bit noisy at high speeds. Michelin's are the best comfort tyres. If you are slightly inclined towards performance then look at Pirelli or Falken too.
chennai
@dhaya, thanks for your calculator. Im not sire about the tyre change. should i change just the two balded ones, or change all four. the other two are in excellent condition . Can i put different brand in the new tyres? with the old Goodyear NCT5 ??
Or im planning 215 60 R 15 , for all four tyres.
chennai
Re: Octavia Needs a Tyre Change
Thanks dodge
Actually my idea was to put Bridgestone Ponteza g3 (directional) so its more grippy than normal GY nct5 , so i thought of putting it up in the front , i though it would handle the turns better. Any idea on this?
Jeno
If the other two are in excellent condition then change only the other two balded tyres. No problem in having different brands of tyres at the front and back. Potenza's are good but are a bit noisy. Try Yokohama S drive have heard good reviews about them.
chennai
Atlast changed my tyres. To bridgestone ER300 asymmetric ,designed for wet and dry(it has different pattern in two sides). I consulted with a mechanic (my friend) and the tyre dealer. They both recommended this model for good life and suitable for indian roads , and due to the fact that my older tyres were GY nct5. I was aware of the noise issue, but this one is not bad(after using goodyear NCT5). Got it done for 10.6k with alignment and rim cleaning. Here goes some pics.
Will tell about the noise and stuffs after driving for 1k kms.
Wheel removed
Fixing the tyres to the Rims
Wheel balancing
Here goes the closer look of the Pattern
Congrats Jeno Bridgestone because of their hard compound they generally last longer than its competitors.
chennai
Thanks dhaya, thought of calling if i had changed all 4 tyres, i changed just two, so didnt want to disturb you . Cos we cant find big comfort or performance change.
Jeno
Need advice to choose better tyres for my Skoda Octy
Hi to all TAI,
My Skoda Octy elegance 1.9 TDI in due for change new set of tyres, the current set of tyre size is 195/65 15" Michiline,
i am looking to upgrade slightly to 205/60 15" or 205/65 15", pls advise which profile tyre to go[cry]
when i ask my local dealer XL tyre point the quoted me 205/65 15"
Yokohoma - ES100 - Rs. 5850 Per Piece
Continental - Rs. 6600 Per Piece and
Michelline - XM1+ - 6150 Per Piece
Primacy - 6950 Per piece,
and my question is, which brand should i go further and let me know the quoted price is reasonable.
and also advice which is the good tyre shop to procure...
Madras
Re: Need advice to choose better tyres for my Skoda Octy
i am looking to upgrade slightly to 205/60 15" or 205/65 15", pls advise which profile tyre to go..
205/60 R15 should be the right upgrade. Better avoid 205/65 R15.
And regarding the price, let me check what we paid for our Civic and update you soon.
