Gear-Up's origins trace back to the military past of the Ural motorcycle family.
The Gear-Up combination is as tough as a Russian AK-47!
Despite its clearly military upbringing, the Gear-Up is equally fit for more peaceful missions, such as fishing or hunting trips.
MSRP:
Forest Camo Gear Up: $13,799
Gobi Desert Camo Gear Up: $13,949
Specification
Model Number- IMZ-8.1037
Dimensions (LxWxH) mm/inches - 2580 x 1700 x 1100 / 101.6 x 66.9 x 43.3
Seat Height- 785 mm / 30.9 inch
Road clearance - 150 mm / 5.9 inch
Dry Weight - 335 kg / 739 lbs
Recommended max speed - 95 km/h / 62 mph
Engine - OHV Air-cooled,4 cycle,opposed twin cylinder
Bore & Stroke - 78x78 mm
Compression Ratio - 8.6:1
Displacement - 749 cc
Rated HP @ 5600 RPM 40
Rated Torque @ 4600 RPM - 52 Nm / 38 ft-lbs
Carburetion Dual Keihin L 22 AA, 32mm
Clutch - Dry, dual disk
Alternator Max Output - 55amp, 770 watts
Starting - Electric & Kick starter
Transmission - 4 forward, 1 reverse, shaft drive
Recommended Fuel - 91 Octane Unleaded
Tank Capacity L/gal - 19/5.0
Front Brakes - BREMBO with full floating disk
Rear Brakes - Mechanical Drum
Sidecar Brakes - Mechanical Drum
Ignition System - Full electronic C.D.I.
Front Suspension Leading link w/Sachs Hydraulic shock absorbers
Rear Suspension Sachs Hydraulic shock absorbers
Wheels Size Front, rear, and sidecar 19"
Wheel Type Aluminum, steel spokes, cast alum. hubs
Miles per Gallon (average) - 26-33 mpg/11-14 km/l*
Trunk Volume - 2.9 cubic ft
Color Olive Drab
Special features Engageable sidecar drive shaft
Warranty - 2 years parts and labor, unlimited mileage
MSRP:
Specification
Color Olive Drab
