I saw this engine on sale on ebay while looking for my car
I am having a new engine swap for my car as well .
This is something that I would love to have .
Its Custom built RB25DET engine , bored to 2.7 L ( originally 2.5 L) 6 cylinder .
Mods on this engine:
Base RB25DET Engine
RB26DETT Genuine Crankshaft
RB26DETT Genuine Conrods
87mm N1 Pistons
Metal Head Gasket
Cylinder Head Port and Machining
Tomei Camshafts 256/256
HKS Adjustable Cam Pulley Gears
Power Enterprise Timing Belt
N1 Water Pump
Low Temp Thermostat
GReddy T67 25g 10cm Exhaust Housing Turbo
GReddy Stainless Steel Exhaust Manifold
GReddy External Wastegate + Screamer Pipe
Full Turbo to Cat Dump Pipe
GReddy Alloy Inlet Manifold
Infiniti Throttle Body
Adjustable Fuel Pressue Regulator
Nismo 555c Injectors
Z32 Air Flow Meter
GReddy Front Mount Intercooler + Piping
Blow Off Valve
R33 RB25DET ECU + GReddy E-Manage
JUN Oil Cap
R32 Crossmember Modified + Spot Welded
Base RB25DET Engine
87mm N1 Pistons
Metal Head Gasket
N1 Water Pump
Low Temp Thermostat
Z32 Air Flow Meter
Blow Off Valve
JUN Oil Cap
