Rallying Classics
Thodupuzha,Kerala
I just thought that many people have not seen what Rallying was like back in the days, when it was all brawn and skills. There were no high tech stuff like Electronics, Fuel injection,Traction control, Paddle shift and even AWD. I will post the link of some videos for you all to see and share the experience.
Thodupuzha,Kerala
Car no. 7 in the video is a Lancia Stratos and though it looks like a spaceship even now, it had no High Tech equipment.
These are the specs of the Stratos:-
Designer Bertone
Number of doors 2
1974 Lancia Stratos dimensions & weight
Wheelbase 2180 mm 85.8 in
Track front 1430 mm 56.3 in
rear 1460 mm 57.5 in
Length 3710 mm 146.1 in
Width 1750 mm 68.9 in
Height 1110 mm 43.7 in
Length: wheelbase ratio 1.7
Ground clearance 130 mm 5.1 in
Kerb weight 980 kg 2161 lb
Weight distribution
(Front) 46.00 %
Fuel capacity 80 litres 17.6 UK Gal 21.1 US Gal
1974 Lancia Stratos engine
Bore × stroke 92.50 mm × 60.00 mm 3.64 in × 2.36 in
Cylinders V6 in 65.0° vee
Displacement 2.4 litre 2419 cc
(147.616 cu in)
Type DOHC
2 valves per cylinder
12 valves in total
Construction cast iron block; light alloy head
Sump Wet sumped
Compression ratio 9.00:1
Fuel system 3 Weber 40 IDF 28 carburettors
Maximum power (DIN) 189.6 PS (187 bhp) (139.4 kW)@ 7000 rpm
Specific output 77.3 bhp/litre1.27 bhp/cu in
Maximum torque(DIN) 225.0 Nm (166 ft·lb) (22.9 kgm)@ 4000 rpm
bmep 1168.8 kPa (169.5 psi)
Specific torque 93.01 Nm/litre
Maximum rpm 7800 rpm
Manufacturer Ferrari
Main bearings 4
Coolant Water
Bore/stroke ratio 1.54
Unitary capacity 403.17 cc per cylinder
Aspiration Normal
Intercooler None
This is another video of the Rally Sanremo 1981 WRC
http://www.youtube.com/watch?v=HgaXIkOnlVQ&feature=related
Excellent thread Jalex. Rallying in those days must have been difficult and much more exciting as compared to todays when the cars have got so much of electronics under the hood for various controls.
Why not share some pics of your rally events. You have been in motorsports i believe,
Thodupuzha,Kerala
Unfortunately I dont have any of them other than the damaged ones I've posted here: http://www.theautomotiveindia.com/f...eriences-amateur-motorsports-2.html#post40474
We did not have digital photography as well back then. All the pics I had were photos and negatives and they all have gone bust with the weather.[sad]
Oh. Thats sad. BTW i have already gone through that thread. Needless to say it was a joyful experience.
Thodupuzha,Kerala
I still haven't finished it yet though.
And here is a video of the 1985 Kenyan Safari Rally and the cars you see are GROUP B Monsters,much more powerful then today's WRC cars. Sadly they were banned after some serious accidents and were considered too powerful to be used at all.
An interesting note is that the Nissan you see between 3.03 and 3.10 is none other then the famous Kenyan Indian Shekhar Mehta.
You can learn more about him here: http://en.wikipedia.org/wiki/Shekhar_Mehta
YouTube - Group B 1985: Safari Rally (Round 4)
Excellent thread Jalex , voted 5 stars! Videos are great though still i have not seen all of them.
Yeah i agree rallying would have been so much tougher those days without Traction control , ESP , ABS and so much other stuffs.
Bokaro/Angul
Awesome.
Great to see somebody with a keen interest in rallying. everybody nowadays shifts to F1. Rallying is the sport which requires Balls.
Stratos. Legendary.
To put more of it in Perpective.
The lancia Delta.
Toyota Celica GT4.
Toyota Corolla.
Ford Escort RS.
Bokaro/Angul
Group B Rally Cars
Heres some info about the group b rally cars.
Audi Quattro sport-
Came in as the first AWD rally car and took the world by storm. nobody could match its pace. An equally wild engine.
The 2133 c.c. all-alloy 5-cylinder unit had 4-valve head plus a big turbocharger. Maximum power in race car reached 500 bhp, while the road car still managed to put out 300 bhp.
Ford RS200-
In terms of technology involved, it was quite advanced - spaceframe chassis, mid-mounted engine, Kelvar body for race car or honeycomb-structured glass-fibre body panels for the road car, 4-wheel drive, twin absorbers in each corner.
The engine was a 1.8-litre 16V turbocharged four-cylinder, made 250 bhp in road trim, but suffered a huge turbo lag due to the high inertia turbo attached for more power. Not very successful.
Lancia Delta S4-
the Delta was built for only one and one purpose only. Beating the Audi and peugeot. And it would have done it if it wasn't for fate.
Mid-engined layout.The engine was longitudinally mounted behind the front seats, directly driving the viscous-coupling LSD which transfered 30% torque to front wheels and 70% to the rear. Space frame chassis.
Engine was another Marvel.
It used a Turbocharger and a Supercharger simultaneously!!
Turbocharger is generally regarded as the most efficient means of forced induction, but it requires higher revs (hence a lot of exhaust gas) to operate. The result is poor low-speed power and the presense of turbo lag. On the contrary, supercharger performs strongly and instantly right from idle, but it is rahter inefficient in high rpm. For a rally car, a flat torque curve over a wide range of rpm is always very crucial, since rally car has to brake to very slow in tight corners and then accelerate to near top speed in 10 seconds. Therefore Lancia spent a lot money with Abarth to develop a system combining both turbocharger and supercharger to get a perfect output. It employed twin intercoolers, one for the turbo and one for the supercharger. The supercharger worked at low speed. Once the turbo cut in, a bypass valve relieved the pressure from the supercharger so that energy efficiency was be lifted.
This system was not only complex, but also faced great difficulties during development. The biggest problem was the transition between supercharging and turbocharging, since a short zero-boost period existed. However, after further developement, this problem was eventually solved.
As a result, the 1.8-litre engine of the rally car had at least 470 bhp on tap.
Peugeot 205 Turbo 16-
Peugeot 205 T16 represented a new generation of Group B cars which could eat the old generation (headed by Audi Quattro Sport) for breakfast. While Quattro Sport was still front-engined, with a heavy monocoque chassis, Peugeot redefined the rules as mid-engined with a space frame chassis.
The 1.8-litre 16 valves turbocharged four generated up to 440 hp in race form, and had a unique center differential which enable on-board selection of different torque slit ratio between front and rear axle.
Thodupuzha,Kerala
The Quattro was one of my favorites, The AWD really kicked other WRC cars where it hurt most. And a French driver Michèle Mouton started to appear on the podium with the Quattro. She proved that WRC is not just a man's sport. That's Michèle Mouton in an Audi Quattro S1 in 2007. I'm not sure whether that was in Germany or is from the 2006 Goodwood Festival of Speed.
Thread Starter #13
Thodupuzha,Kerala
The first picture is from the Goodwood festival of speed 2006 held in the grounds of Goodwood House, West Sussex, United Kingdom and the second and third are from the 2007 Rallye Deutschland in Germany.
Awesome.
I stopped watching F 1 after they brought in the stupid regulations and Michael Schumacher started becoming the sure shot winner at every race. Where's the fun when you already know who is going to win? F 1 is way too boring for me. And very nice to see someone else who is a Rally fan.[clap]
P.S:-Some of the images I posted can be clicked and viewed larger.
Great to know that you are an rally enthusiast Jalex!
I thought many people forgot WRC and shifted to F1, Thanks atleast few still remember.
But when you get a chance, check out todays F1 race, its not the same way it used to be when Schumi was there. Its totally different this season & you will be enthralled :)
