I have been watching this thread silently.
Today morning I saw a Tiago, in our Co Car park in the
funky Orange Color.
It induced a second glance from me. Had a small chat with the owner and thought of adding his inputs here. My younger colleague, started his search with Celerio and ended up with the Tiago.
He is happy with his choice.
Let me compare Tiago and Ignis, from my view point:
Safety:
- Both Tiago and Ignis get "dual Airbags, ABS, EBD and many creature comforts and features". Kudos to both Maruti and Tata.
- I would advice the OP to compare the 80-0 kph braking time & distance of both the vehicles. Whichever has less, should be given two PLUS Points.
- For me weight is an important safety feature. Tiago is 930 kg and Ignis is 830 kg. 18 years ago, weight of my Matiz was 800 kg. If Maruti makes its cars light, by using Carbon Fibre body panels and shifting weight from Sheet Metal to Structure, THEN "this 830 kg figure" is great. Otherwise THIS reduced weight is bull crap. Thicker sheet metals will "protect the occupants from intrusions inside cabin, during the low speed impacts", typical of what happens inside City Limits. Also, a heavier car will be disturbed LESS by cross winds on the highways. Though in high speed crashes, both cars might get damaged equally, I would feel more assured to be inside a Tiago.
Engine : Smoothness, Driveability, Fun and Reliability:
- Maruti's 1.2 Lit engine is a gem, proven, reliable and you can push it to the limits on NHs with a smile on your face. Everything about this Engine is plus plus and plus.
- Tiago's 3-Cylinder 1.2 Lit Revotron is NOT so smooth as Maruti's. I remember reading that Tata has NOT got "Noise insulation inside Cabin" fully right in Tiago. My colleague asked "what do you mean ?", when I questioned him about NVH levels inside Cabin. First timer .
- Though Tiago is NOT a sprinter, my colleague says Tiago pulls cleanly in traffic. He is normally in 3rd gear in traffic. On flat roads, the car moves from zero in 3rd Gear. The way he described it, I feel the Revotron, in 3rd Gear, is sort of an Auto Box for Bangalore traffic. I would say THAT is a very good driveability.
- By comparing the "Max Speed and Times" in "Gears 1, 2, 3, 4 & 5" the OP can decide WHEN to change gears when looking for some Fun. The 3-Cyl will be bit more vocal.
- I had seen some Altos maintaining 110 kph, so I don't think Revotron will suffer to maintain 110 kph on NHs.
- When it comes to the Reliability of THIS Petrol Engine, I can only hope that Tata Motors Ltd does have Certified Reliability Engineers (CRE) in their design group, and those engineers had put to practice what they learnt.
Ride and Handling:
- Being similarly priced, I think both cars are level, in terms of Ride quality. Colleague says he hears "thud" sounds, but Ride is NOT jarring.
- He said it is a bit of a struggle while (parallel) parking, in spite of light steering. This could be due to the turning radius of 4.9meters. Same is 4.7 for Ignis. My Matiz had just 4.5m and my Verna has 5.2 meters. I got used to it.
- Tiago is Colleague's first car (and also at a budget); meaning expectations are limited on "race car dynamics". That said, Tiago being heavier, you will feel bit more comfy while taking on Curves at speeds.
FE:
Colleague is getting an
FE of 14-15 kpl over his regular 7+7 km office commutes. Being light in weight, FE of Ignis will be about 1-2 kpl better than Tiago. As you would be traveling around 8,000 km in an year,
you would end up saving about Rs 2,500 to Rs 5,000 per year in Ignis.
Looks:
This is subjective, but, personally, I feel the "rear and side profile" of Ignis looks
outright lousy.
Tiago is
good looking. Period.
A$$:
Maruti's stellar A$$ network is a plus, without doubt. You will have to sit on their throats in Tata's A$$. Few of my colleagues
take leave, when their Tata made car goes for service, to ensure things are done in the right way. With Tiago having a Service interval of "
every 7,500 km or 6 months", you will have to consume "
two of your leaves" in an year.
NOT ACCEPTABLE, it should be at least 10,000 km or One Year. THIS is the single most irritant in Tiago for me.
Resale Value:
I hate to mention it, but felt it is OK to talk about it in this price point. I am NEITHER seeing this in Bangalore NOR seeing this on the Highways.
Per month, Tata is selling around
7000 Tiagos and Maruti is selling around
4000 Ignis. If this trend continues, resale value of Ignis
could be less than Tiago AFTER 8 years. So, with the Ignis, you gain on FE and loose on resale value.
Final Words:
A car has to meet "what the individual is looking for". I would say both these cars are sort of all-rounders. Depending on how you look at them,
one is bit better in bowling department while the
other is bit better in batting department. If I am playing T20, I would select the bowling all-rounder.
But, you are forced to select an all-rounder for a Test Match (8-10 years)
at Home (65% City use). Generally, IF the "
pitch is cooked up", preference is for a "bowling all-rounder".
Please do tell us, dear Capt. Krishna, "how do you read the pitch" and which all-rounder you have chosen.
