Hi all,
I successfully fixed power hatch opener for my Alto
now i can operate it by just pressing a switch
All I need for this project
1) Push switch
2). old plastic clamp from bicycle bell
3). door actuator (from local seller)
4). wires
5). nuts and bolts
Steps
1). De-assemble the existing manual key mechanism
(did not remove the key lock, only the moving lever between key and hatch lock)
2). Fix the actuator inside the hatch
(moving end of the actuator must parallel to removed lever)
3). join the actuator and hatch lock together (see pic)
4). then wiring ......
5). place the push switch some-ware that safe from accidental press while driving
6). I got power from cigarette lighter connection
YOUR IDEAS WELCOM !!!!
1) Push switch
4). wires
5). nuts and bolts
Steps
