Please Help Me To Choose ICE For Ford Figo
thrissur
Car: ford figo
Budget Range:18k-22k
Looking For: Full Set Up,
Preferred Brands: jbl or pioneer
Preferred Music Type:
Current Audio Setup: naaa
im looking for full setup with subwoofer and amp..hu must be pioneer
Re: pls help me to choose ICE for ford figo
Hi ,
I would recommend the following setup for you.
HU - Pioneer DEH-3490UB( or equivalent) 5-7K
Sub( Recommend a factory made enclosure) - Hertz / Infinity Ref 1260SE ( I own it and its worth it) Hertz for 17K with Bill and Infinity for 15K with bill
If not these enclosure a JBL base tube for 3800 with bill . A sub with a custom made box will cost you around 4K.
Amplifier - GTX 646 6K
Wiring Kit - Schchoche Around 1500-2000
Front Components - JBL gto-609c Around 3800 or Infinity REF6530CS around 4500
Please let me know if this helps.
thrissur
thank for the information...and wht abt the rear speaker? does the jbl amp support subwoofer of 1200 wats?
Hi ,
The JBL sub has 1200 Watt peak power which rarely happens. The sub usually works at RMS power which will be around 300 watts and the JBL 646 will be able to run the sub and the speakers as well.
You can opt for GTO 0949 will cost you around 4K.
Let me know in case you need any additional information.
Noida
I guess figo has a 2-din slot. You can go for Pio 6050 or JVC R400. Both should be around 9-10K. For fronts, get components from RF, JBL, Pio for 5K. For sub I'd suggest you to go for RF P1 in a sealed box. It should be around 4-5K. For amp you can choose from Kenwood 846 of JBL's 646 though I prefer Kenny for their clean output. They retail for around 5-6K. Add another 1-2K for RCAs and wiring. Now, if you can still shell out a few grands, go for rear speakers for around 2-3K or you can add them later.
freakdude.
