I would advice you to get the installation done in stages.
First you buy a decent amp. let it be costly to make sure you won't be changing it in near future. Masconi AS100.4 is an example, it has true 100 watt per channel at 4ohm and 320 watt in bridge mode at 4ohm and 480watt in bridge mode at 2 ohm(mind it its the only amp which can be bridged at 2ohm).
Buy a decent pair of compos along with subs and use it for decent amount of period. If you still feel the need of rear fills then you can get a mono for the subs and rear channel of amp to power the rear fills. Who knows if you would get satisfied with this setup, then you can surely save plenty of money.
Specify your budget. It would help us to help you choose right stuff.
Imp: Don't ever use your speakers without MDF rings.
I am not tight on budget but i don't want to spend unnecessarily. Looking for VFM products but i am flexible and can increase the budget if the products are worth it.
My current list includes the following:-
Head Unit - Pioneer AVH-X5590BT - 25k
Product info - AVH-X5590BT |
Front Speakers - Polk Audio DB6501 Component Speaker System - 8k
Product info - db6501 - Car | Polk Audio®
Rear Speakers - Rockford Fosgate Prime R16-S Component Speaker - 6k
Product info - PRIME Speakers - R16-S - Rockford Fosgate®
Amplifier - Rockford Fosgate 250.4 4 channel amplifier - 8.5k
Product info - PRIME Amplifiers - R250-4 - Rockford Fosgate®
Subwoofer - Focal P-30 12in with custom enclosure - 10k
Product info - Focal Sub P 30 DB, car audio hifi subwoofers to customize your car sound system.
Scoche Amplifier Wiring Kit - 1.5k
Total costs - 59K without installation.
Budget can be upto 75k for the whole setup and installation but not more than that.
That Masconi alone would shoot him with a 35-40K man!!! Not doubting it's capabilities but I find Masconi's over-hyped. Rest all depends on ones choice.
freakdude.
freakdude.
Sankar
