My Scorpio VLX - Powered By mHawk!
raj_5004
Dubai / Mumbai
300 kms review:
now, i wont call this a review, but here are some things i noticed in the first 300 kms with my car:
+ tyre pressure sensor is good, accurate with only a negligible error.
+ reverse sensors work well, shows even the direction of obstacle and detects even the corners of the bumper.
+ cruise control is working fine, no issues there.
+ engine is very very refined, its all go and no show! amazing acceleration with zero vibrations.
+ features like theatre style illumination & headlights which stay on for 30 seconds after you remote lock the car add to the "feel good" factor of the car.
+ the voice assist system reminds you of everything from low fuel to seat belt, door open, low brake fluid, handbrake engaged and what not!
+ the lights on the footpegs are nice and do help.
+ driver's window has auto up/down feature with anti-pinch which goes down automatically as it senses an obstacle. nice.
+ automatic headlights are working fine, but does get switched on if the car is parked in a shed even in daytime.
- there is some vibration from the gear lever in the 3rd gear. have to get it checked in its 1st service.
- there is a strange sound like "whoa" from the car. it is not sounding like a defect or rattle. its like the car is purposely making that noise as a reminder or caution, but we cant figure out what it is!
- the ride though good, should have been better.
- small shortcomings which i already knew like absence of cruise control indication and electric side view mirrors.
- automatic wipers work fine but does not stop as soon as the glass is dry. this is mentioned even in the manual as the sensor senses even little drops on the windshield.
850 kms review:* because of the rains in mumbai, i could check my car's automatic wipers. they are working perfect, quite contrary to what i read in some reviews. switches on/off automatically and increases/decreases speed according to the intensity of rain. the only grouse is a mild clicking sound can be heard from the sensors's receiver located under the front seat. i dont know whether its normal, anyways have to get it checked in the first service.
* the strange noise like "whoa" which i mentioned earlier is still present. now we are sure that its not a defect as we have heard it even when the car is not moving but we have no idea what it is trying to convey!
* if the scorpio is remote locked, then it should be unlocked only with the remote as the engine immobiliser get activated. any attempt to open it with a key will trigger the alarm and the engine wont start. if your remote battery is dead, then you can open the car with a key. to stop the alarm, there is a button in the glovebox. turn on the ignition, press this button and turn off the ignition. repeat this procedure five times. this is the way to enter your password. your default password is "11111". you can even change your password!
* there is a small procedure you have to do when you have a flat tyre. the TPMS (tyre pressure monitoring system) indicates with a beep and red light that you have a flat tyre and also indicates which tyre is flat. first manually swap the tyre with the spare. then press the mode button on the TPMS twice for 5 seconds. it will beep to acknowledge your request that you have swapped the respective tyres.
* in my 7 seater version, mahindra has pulled back the middle seats a bit behind resulting in more leg space in the middle seats.
* i dint like the fitting of the panel behind the steering wheel. looks like it has been cut with a knife! rest is ok.
* we use premium diesel by indian oil and bharat petroleum. its working fine. engine is smooth and refined.
* the vibration which i mentioned in the gear lever still persists and is only in the 3rd gear. has to get it checked too.
lastly though i am very impressed with my new car, my hand is itching to press the throttle real hard and to exploit the engine's full potential. wish i get the first service done soon. i wanna feel the power of that 120 horses.
5000 kms, 1st service update:
PART DESCRIPTION (QTY.) RATE as follows:
OIL FITER (1) 127.11
GEAR OIL (2) 307.54
DIFFERENTIAL OIL (1) 218.66
ENGINE OIL PREMIUM (6) 840.00
COTTON WASTE (1) 8.88 (ridiculous!!)
W.D. 40 (1) 43.75
TOTAL: Rs. 1545.94
NOT INCLUDED UNDER SERVICE:
MIRACLE TREATMENT (underbody anti-rust treatment) : Rs. 3500
INITIAL HICCUPS FACED:
1. the "whoa" sound coming from the day of delivery itself was finally solved after 3 visits to the workshop! it was traced to the AC motor. on the 1st visit, one of the 2 motors was replaced under warranty. on the 2nd visit, the 2nd motor was replaced. on the 3rd visit, the expansion valve costing Rs. 300 was replaced under warranty. after that, this problem did not re-surface, touch wood!
2. excessive gear lever vibration in 3rd gear not solved. found to be present in all mHAWKs.
3. central locking system by nippon found to be a bit unreliable. a month back, it was working but refused to emit the siren while locking/unlocking. worst is that mahindra dealers do not attend to such complaints. they gave us the number of nippon customer care who will send a person to our place to rectify the complaint. 3 days back, just before the vehicle was to be sent to the service centre, the remote stopped working. but the next morning, it started and is working fine now. i think it must have got wet in the rains, irresponsible driver and poor nippon quality!
4. service by the mahindra service centre (GLOBAL GALLARIE, MUMBAI) is good. the staff behaviour is good. when i called for an appointment for the service, they informed me well in advance about the routine work that will be carried on my vehicle, the parts that will be replaced or checked, what i have to carry with me and the bill amount. vehicle was delivered on time and washed properly including the tyre polish. my beige seats were not spoiled!!!
overall, the vehicle is perfoming fine. the mHAWK engine still suprises me everyday with its amazing power delivery. i am getting an average of 9-10 kmpl in mumbai city. on a recent trip to pune through the expressway, i got an average of 13 kmpl which i think is sufficient since it was doing speeds of 120+ kmph and even the worse pune traffic! felt very stable at speeds of 140-150 kmph with no probems faced. engine was still very refined and the sound was not much of a bother. but above 120 kmph, wind noise exists.
sensors are working fine. cruise control and auto headlights only put to use on express highway. auto wipers is a boon. it works spot on, a superb feature. rear sensors are also good. wish the fog lamps were better though. tyre pressure sensors are good and almost accurate with an error of +0.5 psi.
TOP SPEED TOUCHED: DAY: 30th october, Thursday
Destination: Pune
Route: Mumbai-Pune express highway
this was the brief given to me and i had to reach pune by 8.30 am. so i started off from my house by 5.00 am. it was a chilly morning and traffic was sparse. i reached the expressway in 30 mins flat! normally, it takes an hour! that gave me a thought that i have never gone above 150 or actually tested the top speed of my scorpio, mainly due to traffic conditions. this, i thought, was the perfect oppurtunity. a few kms past the expressway, i set the cruise control at 130 kmph and continued like that till the first toll naka. you can say, i was warming up my car and myself. there onwards, i simply floored the throttle. with the pedal touching the floor, 150 kmph came in no time. then slowly and steadily, the needle rose and finally it touched 170 kmph. after this, i let go as i entered the ghat section! though i know mahindra claims the scorpio has a top speed of 156 kmph, but i must have atleast touched 160 kmph, maybe due to road conditions, i consider an speedo error of 10 kmph.
what i noticed was, even above a speedo indicated 150 kmph, the engine noise was not that audible but what was more pervelant was the wind noise which started at around 140 kmph and increased gradually. also, 1 thing i liked was the SUV felt steady at such speeds, unlike what most say. i left the steering at that speed and the scorpio travelled a straight line without even a slight deviation. yes, i dint try any heroic stunts like sudden lane changes to check its handling! i leave that to professionals!
overall, i was AGAIN impressed with the engine as it was very refined throughout not sounding coarse at all. tyre noise was also under control. but i wish there was a bit less wind noise. mahindra, please look into this!
More reviews will be followed soon!
raj_5004
Dubai / Mumbai
10,000 kms in my Scorpio VLX :
Here is the description of the 10,000 km service of my mahindra scorpio VLX done at Global Gallarie (authorised A.S.S. of mahindra in thane, mumbai):
Service: Second Free Service
Kms. Run: 10604
Emery Paper --> Rs. 12.44
Maximile Coolant --> Rs. 116.75
Total --> Rs. 145 (including VAT)
As you can see, nothing was changed or replaced, only the coolant was topped up.
Other jobs done:
1) a minor brush with a bus had left a scar on the right RVM, it has been given a paint touch-up.
2) some rattling could be heard from the rear left door on rough surfaces sometimes. it was traced to the rear seat whose folding mechanism was tightened, problem solved.
3) the brakes had a tendency to squeak on light application. the brake pads were cleaned and adjusted. problem seems to be sorted till now.
Rest, the car is running fine. the service has been good and all complaints attended. the car was given today morning 11 am and returned back by 4.30 pm. the car was washed properly and tyre polish applied.
the FE has been 10 kmpl in city. no complains from the engine or gearbox but the vibrations in 3rd gear still persists.
my short review:
+ responsive engine with great driveability
+ refinement / NVH
+ auto wipers/headlights (useful to me!)
+ tyre pressure monitors (its very accurate with an error of +1 psi)
+ voice assist system (i personally like it more than buzzers and lights)
+ styling and road presence
- not so good ride quality
- gear lever vibrations in 3rd gear
- no airbags
- no indication for cruise control
overall, i am very happy with the vehicle and i would definetely suggest it as a worthy buy.
15,000 kms UPDATE:
My scorpio mHawk has just completed 15,000 kms a week back. today it went for its 15,000 kms service. the car went to the A.S.S at 9.30 am and was delivered by 3 pm.
Total cost incurred: Rs. 467/-
I wont describe the pros & cons anymore as i have talked about it many times already! both the pros & cons still remain!
Major issues: None
Minor issues:
1) Gear lever vibration in 3rd gear still persists. i again re-confirmed that it is present in all mHawks.
2) the driver's door sometimes used to squeak over rough roads. door nut tightened, problem solved.
Other than these, the car is running fine. However 15,000 kms on busy mumbai streets has left some marks on my scorpio. a sumo rear ended on my stationary scorpio, this has left a small black mark on the left side of the rear bumper. a idiot guy brushed his civic against my AGAIN STATIONARY scorpio which left AGAIN a black mark on its left mud flap.
its giving me an average of 9-10 kmpl on crowded city runs and 13-14 kmpl on mix city-highway runs. all figures ith 100% AC. i know its less but thats mainly due to my style of driving, i have the habit of flooring the throttle in every gear.
Accessories:
1) black vinyl on B, C & D pillars: looks nice & has stuck well.
2) Garware reflective film: i am not too happy with the choice of the sun film.
3) Carryman front guard: the best accessory of my scorpio, looks excellent and no problems whatsoever.
4) JBL basstube + Sony 4 ch amp + 2 sony 400W ovals: all are working fine.
5) Roots windtone 90 horns: working fine & sounds great.
To be installed:
1) alloys
2) dump sony and install JBL on front & rear + a new HU
this is happen as & when Vitamin M pours in.
2 incidents happened within 2 days which i thought is worth mentioning in my ownership report:
1) yesterday, i was driving towards mulund from byculla on the eastern express highway. it was a dull afternoon & traffic was light. i was driving on the right lane at about 110 kmph. few metres away i see this 'tata 407' tempo trying to get into my lane. i flash my headlight and honk twice since if i let him come into my way, i would have to brake quite hard. judging my speed, the temp cuts back into is lane and gives me the hand signal to pass. at about 90 kmph, i again accelerate to pass and just as my car's nose reached his front tyre, very abruptly he cuts into my lane. that is followed by my emergency braking and a little swerve to the right. the scorpio came to a dead halt from 100-0 kmph in a perfectly straight line... no drama, so skidding & no screeching. i could even feel the ABS work through the brake pedals. there was no front end dive as expected. i was greatly impressed by such a braking performance. THE ABS DEFINITELY WORKS.
2) today a santro hit my parked scorpio while he was parking. the santro's damage was a badly dented front right fender. the damage to my car was a scratch on the rear left cladding! i enquired at the mahindra showroom as what will it cost to get the cladding re-painted, they say its 1500. this tough build of mahindra is what i adore.
meanwhile, an unscheduled visit to the A.S.S. happened:
reasons-
1) as i said earlier, the santro guy had scraped the paint, so re-painting was to be done.
2) some tik tik noise from the driver seatbelt on rough roads
3) driver door squeaking on rough roads.
solutions-
1) re-painting was not necessary according to the A.S.S as the damage was 'NIL'. they did a free touch up job. they did a good job, its hardly noticeable.
2) seatbelt problem solved.
3) driver door along with all doors tightened & adjusted.
4) i had asked them to check for each & every noise in the cabin on rough roads, so they tightened the middle row seatback too. now the car's cabin is as silent as when new.
5) meanwhile, i opted for mahindra's 'MIRACLE TREATMENT'. Its basically an underbody treatment, an anti-rust coating. for the coating to be applied, they had to clean the car's underbody first & then apply the coating, but obvious! so now the wheels, wheel wells, shocks, etc. look spanking new!
6) the rear glass washer was not working, the washer container was choked. they replaced it under warranty.
so total cost incurred:
MIRACLE TREATMENT = Rs. 3500/-
WC TAX = Rs. 280/-
WSER TAX = Rs. 360/-
TOTAL = Rs. 4141/-
raj_5004
Dubai / Mumbai
my scorpio has done 18,800 kms. an unscheduled visit of my scorpio to the A.S.S. took place.
reasons are the driver door squeaking re-surfaced & the AC performance has dropped drastically. as mumbai's temp levels are increasing day by day, i am finding it more difficult to sit in the cabin. the AC doesnt make me sweat but it does not cool the cabin to a comfortable level either.
Reasons could be:
1) some major fault in the coil/compressor/etc. or gas leakage.
2) my car is parked under a small tree which showers its blessings on my scorpio in the form of small dried leaves. every morning when i see my scorpio, the bonnet is fully covered with brown dusty leaves. even on the previous 3 visits to the A.S.S (schedules services), the mechanics have remarked that huge amount of leaves are found in the AC filter. i suspect even this time, these leaves have choked up the filter & hence the throw of cool air in the cabin is less. earlier i used to set the AC at 2-Low, now i have to keep it at 4-High, just to avoid sweating!
UPDATE:
Got a SHOCKER yesterday! the estimated bill amount is Rs. 10,000!
this includes the 20,000 service & AC servicing. As soon as the third free service is over, these guys started thinking ways to mint money.
My major issue was the AC was not cooling well. On inspection, they found out that the AC filter (as expected) was clogged with leaves & hence the throw of air in the cabin was less. Also, they told me that the AC coil is found to be functioning less than perfect, so they will replace it under warranty. but that will require them to service the entire AC unit. (Does replacing an AC coil demand an entire AC servicing?) The cost of AC servicing & gas refill (Rs. 3000) will be on me!
The A.S.S dint have the AC coil in stock, they will get it tomorrow afternoon & i will hopefully get my car tomorrow evening. Meanwhile, the 20,000 service & the door squeaking issue has been solved.
20,000 service details + other minor issues:My car was driven into the A.S.S on 11/05/09 for the problems mentioned in above posts & was deliverd to me today, that is, 13/05/09. The delay of 1 day happened because the AC coil which was to be replaced was not in stock.
anyways, here is the break up of the service bill:
1) Maximile supreme oil - 6 lit. - Rs. 912/-
2) Oil filter - 1 - Rs. 138/-
3) Max treat (Oil additive added on my request) - 1 - Rs. 346/-
4) Fuel filter - 1 - Rs. 1445/-
5) Washer - 4 - Rs. 64/-
6) Cotton Waste - 2 - Rs. 17/-
7) W.D. 40 - 1 - Rs. 54/-
8 ) Mafron 134 Gas (For AC) - 700 - Rs. 420/-
9) Refrigerant oil 13 - 100 - Rs. 150/-
Labour Charges:
1) Change engine oil - Rs. 300/-
2) Fuel Filter - Rs. 300/-
3) Vehicle Washing - Rs. 450/-
4) AC service - Rs. 3000/-
VAT + Sales = Rs. 443/-
TAX = Rs. 417/-
TOTAL = Rs. 8459/-
# Whats shocking:
1) Rs. 17/- for the cotton waste!!! why are they acting like beggars?
2) Labour charge Rs. 450/- for vehicle washing! does every A.S.S. charge for this?
# After Effects:
1) AC complained solved after replacing the coil. the throw of air is fantastic & the cooling is superb. now i dont need to go above 2-Low! it chills to the core, just like when it was new!
2) driver door squeaking issue is solved. but i am not sure when it will re-surface again.
3) Engine sounds & feels a bit different now. a bit more smooth & more responsive at throttle inputs which is good.
4) Although i have cribbed about it above, the washing guys have done an excellent job. my car is sparkling clean on the outside. even the interiors & the AC vents look new. the doors, mats & dashboard look fresh. (AC vents must have been cleaned during the AC service)
5) i dont know for what reason, but the gearshift has become a bit smoother than earlier!
6) My beige seat covers were not dirty, good.
7) Steering is a bit tilted towards right, i bought this to the notice of the service advisor after my TD, but since it was too late (8 pm!), the staff had left! the advisor told me to bring the car tomorrow or whenever possible, he will rectify that for me.
# Verdict:
Though the bill amount was a bit on the higher side, the condition in which i received my car bought a smile on my face. This seems to be my new improved scorpio with spanking clean body, smoother engine & gearbox
vijay
Moderator
Ahmedabad
good precise review of your ownership of scorpio vlx, now what i think is that this machine lacks airbags else is a best contender for city as well as highway cruising.Mahindra has offered some of the best detailed list on this scorpio which first starts with its Mhawk engine which is a gem in itself, second Cruise control, parking sensors, auto wipers, tyretronics which are soo effcient to use that one does gets used to this gadgets so easily.
Awaiting for some pictures buddy!
Fuel filter 1445rs and labour for the same is rs 300? The bill is very high.
Compare with Innova's bill and update us. I'm keen to know about it too.
Tata, Mahindra, Skoda, Hyundai, all cost a bomb to maintain.
raj_5004
Dubai / Mumbai
pictures, yes... let me resize them first.
airbags- mahindra wont offer them until the scorpio stops selling!
yes, the bill is on the higher side but cheaper than toyota. diesel fuel filters are expensive.
you have included all companies except maruti!
Nice Review & Precise OwnerShip Update!
thanks buddy. [:)]
vijay
Moderator
Ahmedabad
well i dont think tata mahindra and maruti costs bomb to maintain, infact if you compare them with toyota, honda and skoda, these indian companies are quite reliable and chaeper to run as well as maintain their cars.Few parts are yes expensive but not that huge i believe.
Man i just love this car.
But the thing is here the "gaon ke people" are so mad abut the car that they go on buying one after another that too mostly in white & giving fancy numbers etc its like they have changed the image of this car here.
Like when we see a bullet and a tall guy on it the first thing comes in our mind is Police.
the same way here when people see a scorpio they call the people inside as gaon valle.[frustration]
I have a gaav valle feeling on seeing a Tata Sumo.Sumo's in Mumbai are worst driven and hence gaav valle[:D]
Mumbai TAI members will agree.
vijay
Moderator
Ahmedabad
You really know how to "fill up" a Scorpio.[clap]
you should also see the picture of middle bench as well, which was filled with luggage as well with last row.[:D]
scorpio and safari are well trusted suv's which are reliable, easy on pocket and tough on roads as well.
Thread Starter #15
raj_5004
Dubai / Mumbai
yes, i have seen this a lot in pune. a lot of rashly driven white scorpios there with VIP number plates.
i agree. Especially call centre sumos.
thanks buddy. luggage was filled in the middle row too!
here are the pics vijay is talking about.
