My Santro Car Crank Soft Problem - Advice Needed
Dehradun
There is one problem with my car for last 3 months. On slowing down engine is stopping and I need to use accelerator to keep it up. At good speeds this problem isn't visible.
Looks like some tuning is needed and same used to happen with my 2 stroke Yamaha bike which I could change just by rotating one tuning button..
But the Hyundai authorized service center told me it is crank soft sensor problem and it'd cost me Rs. 5500.
Can someone expert in Cars tell me if this could be correct?
You could not manually tune in mpfi cars.
the crank shaft or cam shaft.
Above the valve door you have a sensor . its failed reading may cut off fuel supply. I hope its that costly.
Age of car? Normally that sensor do not malfunction that easily , that is build to serve till last. else some one in service center interchanged it with their friends or know car - which happens regularly.
