My First Car: Maruti 800 AC 93 Model
Thread Starter #406
Lucknow
hi shantanu bhai,my cars roof cloth is cut from one place so can u tell me the cost and the place in lko where i could get it done
@ Vaibhav Go to Shyam Auto Agency or any shop in the complex opposite fire station in Lalbagh. Roof cloth is available for Rs 150. Glue for Rs 50. If you want a used type 2 roof, then search the local scrapers in moongphali mandi or Kanpur Road.
Today's Update. Dedicated the day 11/12/13 to my car.
Replaced the rear dampers, engine oil and the rear bearings. Cleaned the plugs and air filter.
1. Monroe brand dampers for Rs 550/pair
2. Servo 20W40 oil for Rs 730
3. Oil Filter Purolator for Rs 60
4. Rear Wheel bearings 4 nos for Rs 450
5. HP Grease for Rs 50
Result: Smooth running engine and no grunt or harsh engine sound. Pick-up increased too. No khat-khat noise from the rear and better ride quality.
There are very less pics as it was a DIY. A bolt holding the damper was stuck and made the job hell. At last it was cut using a hacksaw blade. Pics will be updated tomorrow.
lucknow
thanks shantanu bhai for the info.one prob now arise in my car in night.the light are very dim.yesterday i canged both of my headlights but still no change.can u tell me what i can do.and for foglamps my daddy is not allowing me to drill holes in bumper so where else can i mount them.its just becomming impossible for me to drive my car at night.need suggestion immedately[cry]
Thread Starter #409
Lucknow
Did you replace the damper with the oil ones or the gas ones ?
I have used oil filled ones
Why dint you consider mgp..
Earlier in friend's garage we had fitted these brand shockers in customers cars and the performance was good. Price difference was also a factor
Check your battery for low charge. Which brand bulbs have you used now ? Check the earthing wires of the bulbs and relays
Fog lamps can be fitted using clamps on the bumper, but few small holes may be drilled
Start an ownership review with more details and pics
Thread Starter #410
Lucknow
Was willing to dome DIY for my car, but due to short budget could not do some big projects. So decided to make LED driving lights. I am using these 1W LEDs for emergency light etc.
3 LEDs are connected in series with a 30 ohm resistance.
SORRY FOR POOR QUALITY PICS
Earlier the indicators and parking lights were like this
Bought 50 LEDs for Rs 100
30 ohms resistance @ Rs 0.50 per piece
Pasted the LEDs on a aluminum strip, this will work as heat sink too
The light cover was made using a frooti bottle. The plastic quality is better
All LEDs pasted and soldered
The final product
The indicator
These pics are taken using only the LED lights
Nagercoil/Kollam
The final product
The indicator
test and report the life of this LED after some days. it blew off soon for me due to improper heat sink
Thread Starter #412
Lucknow
1st update in year 2014
Bought an oil can for Rs 50
And Suzuki Stickers for Rs 60
Now thinking where to put the stickers
1 Front Doors
2 Rear Doors
3 Somewhere else ???
Thread Starter #413
Lucknow
Hey friends,
Finally I am back with lots of updates. The phase 2 restoration has begun. Special Thanks to Anand Bhai (SS80) for sending the Minda wiring harness for my car. In my city minda wiring harness was not available.
My restoration plan includes
1. Changing Complete wiring harness
2. Sound/heat reduction in the cabin
3. Red and Black interior with type 2 roof
4. Repairing the AC
5. A better music system
6. Multicolor underbody and interior lights
7. Power Window Kit (if budget permits)
8. And few more accessories etc.
Few pics:
Thread Starter #414
Lucknow
Sorry for being away for a long time as I was too busy in office work.
My second phase restoration had completed long time ago and the car is working fine now.
Lots of updates and pics are there which will be posted soon.
Few of the updates are:
Proper working AC
New ICE DVD Player+Sony Speakers+Worldtech Bass Tube
New Interior Red & Black
Type 2 roof molding and few more.
Today posting the pics of Vishwakarma Pooja done at home
Shantanu, I liked all your DIYs .[:)]The white colour is cool.[lol]
BTW, no updates for a year?Can you post some interior photos?
With Regards
Shrijit
by running lights you mean DRL?
that's cool bro. the designs you've done is perfect and 30ohm resistors on 14.4v will. drive each led At 150ma which will prevent led from blowing.
however next time, use a simple DC DC converter. it's available on eBay for.Led. rs 80.
kudos to you bro!
hassan
Hi shantanu I liked your diy I like to do some on my car . I like to install LED inside the cabin could you help me with circuit diagram . my ride is m800 2000 model
Dear All,
I had requested for some information regarding wiring from Alternator to the battery, but nothing received. How ever I have changed the cable from the old alternator (Maruthi 800AC) to the battery with thick wire used in Inverter. The old wiring was giving eratic reading from 12.8 to 13.7V without any load. Battery was not gettin charged and many problems. Today I used the inverter wife and fixed it to the Alternator. Also I removed the same wire connecting the battery. There was no power coming and could not charge. How ever I connected the old wire to the battery leaving everything as it is. Then I started the car and it started without any problem. The power was steady at 14.17V. Two questions. Is the earlier wire connected to the realay or to the key? Second how to remove the old wire and use only the thick wire? Once I am through with this will change the Alternator to Swife.
Also how to check a used alternator as I have already found one in Pudupet, Chennai. If able to check confidently buy it and fix.
Thanks
V Krishna Swamy, Chennai
you will need a DC capable clamp meter to check the current flow. it should be about 10amps from alternator to Battery.
