Mitsubishi Lancer Technical Problems & Solutions
Re: Vibration in Lancer when Switching on A/C
What your mechanic say is right
if the vibration stops once you press accelerator.
if that is the case , the valve must be clogged due to dust , remove and clean them with rust spray/thinner /petrol or anything like that.
The reason is inadequate diesel supply on load!
Thread Starter #17
the entire part is a sealed one. no screws to open. I gave for sample otherwise I would have uploaded picture. will upload once I get new spare.
thanks for your valuable suggestions.
Thread Starter #18
Lancer Diesel Poor pickup
My 2000 Model Diesel Lancer (1,12,000 on odo) having less pickup. Whenever I switch on A/c pick-up is further coming down.
Can anyone suggest a way to improve pick-up..
Thanks in advance.
Re: Technical Issues & Solutions in Old Mitsbishi Lancer
Note: Different threads related to issues in Mitsubishi Lancer have been combined into one. Let’s continue further discussions in this topic itself. Thanks.
Thread Starter #20
Please help me to identify this part
Hi TAI-ns,
Please help me to identify this part which belongs to Mitsubishi Lancer Diesel.
Also, let me know the purpose of this spare.
This is located just above the throttle body.
Thanks.
Thread Starter #24
Sound after changing all belts - Lancer
I have recently changed all below rubber belts:
1. Alternator
2. Power Steering Pump
3. A/c Compressor Belt
After changing this, I am getting some sound (Kreeeeech!!) in cold start and is going off after driving some 100 metres.
During long run, I am not getting this sound.
Can anyone suggest which one is making this sound ?
Note: Sounds seems to be coming out from belts.
Thanks.
Technical problems in my Lancer
I am new to Automotive India. I have a diesel Lancer (2001) and I am very much addicted to it. Due to its vintage now a days it is giving some problems.
Issue 1 : Suspension:
* Changed suspension kit (including lower arm / bush kit/ etc). But my Mechanic did not replace existing coil spring. He had tempered it using "Spring Tempering process" (dont know about it).
* Gas shocks has been replaced.
* New tyre replaced.
Now, whenever I drive on bad roads (especially pit/pothole on straight road), I dont feel any suspension. But If I drive on curvy ups and down, I could feel the suspension. The issue with both front and back.
Somebody can suggest, whether the problem is with Gas shocks or old coil springs ..
Issue 2 : Grinding Noise
Past few days, I could hear some grinding noise from dashboard. I am not sure whether this is rattling noise or grinding noise). During Idling, even If I give throttle, I dont hear any rattling or grinding noise.
* I have removed all things from dashboard box but no result.
* I dont think problem with Gearbox as have changed clutchplate/release bearing everything before 6 months.
Also, suggest for this issue also..
Varun560061
Re: Sound after changing all belts - Lancer
1. Alternator
Thanks.
Just tighten the belts, the sound will vanish. This because the belts are slipping on the pulleys.
Grinding noise in low acceleration - mitsubishi lancer
I have a Mitsubishi Lancer 2000 Model.
I hear some rattling/grinding noise in low accelaraion which goes off in high speeds.
what could be the reason for this noise..
Senior TAI-ns .. Please help
PALAKKAD
Help Me In Identifying the engine...
I have a 2002 model diesel lancer with 68bhp engine. I am unable to find the model of the engine and its details. Somebody please explain about this engine and the best engine oil that can be used for best mileage and performance. (I live in palakkad)
PALAKKAD
Uneven tire wear problem
My car's tires were having an uneven tire wear when i bought it. Recently i checked the wheel alignment and made it right. Is there any other reasons that could create this problem, What are the things that i should check? It is having 175/65R14 tires filled with nitrogen, What is the correct air pressure?
