^Thank you for your kind reply saroya. Can i not simply install just the bulbs without relays? Also which bulbs and which relays, kit is recommended considering it is old model of DZire? I read that Philips Rally and Philips relay kit are the choice. Where do I get these in Original? And do I not need to replace the holders to ceramic to handle additional heat? I am also reading that 130/100 are overkill and 100/90 should be sufficient. Any ideas?
Also I do not understand will they fit into Highbeam slots of Lowbeam slots? Or these act as both highbeam and lowbeam?
Thanks again.
I don't know if your car has H4 bulbs ( single bulb for both low and high beam) or not. If those are with H4 setup, then install will be very simple and plug and play like no modifications to existing wires needed.
wiring kit include relay, fuse , ceramic holders. For wiring kit prefer Philips , Minda, Hella. For bulbs i will recommend philips Rally 130/100 watts or 100/90 watts.
I have experienced philips 130/100 watts in my Alto. I can bet even bus and truck drivers will respectfully swith to low beam after facing your high beam flash.
Original wiring kits are available in market easily but finding original philips bulbs is difficult job. Some online stores also like snapdeal, ebay have original products.
