Maruti Swift Dzire (Old Model) Headlight Upgrade
I have Maruti Swift Dzire (old model) car and facing issue with my headlight. I have installed Philips relay which can support 100/90 bulb but due to high load headlight holder burnt.
Can someone please advise me good headlight holder which can support 100/90 bulb and also advice me website / shop in New Delhi from where I can get it.
Thanks in advance.
Anurag
M.P.
Re: Maruti Swift Dzire (Old Model) Headlight
Contact this guy; he may be able to help or guide you to something better:
Manjit Suri
Motobike Performance Parts
+91-9811422626, 011-45604388
1617 / 32 Nai wala,
Shri Kishan Dass Road,
Karol Bagh
Thanks Sam for your reply.
I have contacted and he advised me to install new kit which will cost me 6500/-. I am only looking for holder which can hold load of 90/100 bulb because if i change complete wiring kit then current one will go on waste only.
Please help me to find holder.
Hoshiarpur, punjab
6500 rupees:eek:
100/90 wiring kit (wiring with ceramic holders+ relay+ fuses) cost some 500-600 rupees.
Can you please tell me from where i can get this product and also which company is good Hella or.some other.
Hoshiarpur, punjab
I am using MINDA wiring kit from almost a year. No problem till date. Purchased for rs. 500 from local accessories shop. My headlights bulbs are Philips Rally 130/100 Watts .[:D]
Ok please tell me u have 130/100 bulb so is there high load on battery or on altenator i heard somewhere if you go for high and blubs then battery usage is high or also load goes to altenator which is somewhat on higher side. I am not sure so please advise me.
Hoshiarpur, punjab
As said earlier, no problem at all. My car also has fogg lights, sub with amp. Never faced any overload or battery discharge issue.
Ok...please advise which company wiring kit i should go for to replace 90/100 blub to 130/100 blub.
Dibrugarh
Some months ago I purchased Hella wiring harness kit suitable for upto 130W from ebay dot in for using it in my Maruti 800. Came with ceramic bulb holders. Installed with Bosch 90/100W H4 bulbs. Running Fine till date[:)]
You may check it out.
The wiring kit which I have is philips h4 relay kit with creamic holder and it will also support upto 130/100 w but to be on safe side wanted to know about load on battery and on altenator. Someone told me that load is high on altenator n on battery when u have 130/100 w blub so not sure about it.
Please advise.
chennai / Blore
Anurag, I was also using 100/90 wiring kit and had same problem of burnt Head light Holder ( Only on right side headlamp) Replaced it with swift OEM only. It's almost 2 years now and there are no issues. Only precaution I take is I do not keep the head light burning for very long time, when at signal or toll gate I switch off my headlight for few mins and that solves the problem !!!
Thread Starter #14
So the OEM which you have now it is same 100/90.
Also, someone advised me to remove bulb holder which is default in dzire and connect only blubs with relay holder so I am not sure it will be good option or not. If you can please advise me.
Madras
Is it one or both the holders burnt? Something new to hear regarding Philips HL wiring harness. I suppose it may be manufacturing defect.
Before changing the entire kit, get new ceramic holders alone and replace them on the existing harness to check if the problem is solved.
