Thank you for the response - I like to update here, (the car is in the same condition).
It is the battery, The headlights are DIM when on the battery (like Torch) and the voltage reading is in general 12.26v and now after nearly two weeks no usage today the reading is 12:13v...but in this process it may blow out the power window fuse. Hopefully, I'm able to change the battery by this week. According to the user manual, the power window fuse is in the Engine Compartment 'Power window, Ignition,
Wiper, Starter - 50A'
I do install a Chinees Andriod HU in August 2018 but I'm sure it is not that, I removed that HU, Andriod Smart Mirror (March 2018) and Dash Cam (May 2016) once the problem cropped up 2 weeks ago, Checked with OBD HUD module two weeks back and there is nothing.
I will update here as event goes.
Was any electrical fitment made (accessory) recently?
One way of diagnosis is OBD scan the vehicle , also check with the fuse box(I recommend you to take to MASS)
