Maruti Suzuki Omni Overheat Problem
hyderabad
hi i have maruti omni and i am facing overheat problem so i have been change the head gaskit also after changing the head gaskit i have been not face the problem for a week after a week the problem starts so please tell me solution
pune
i m too facing same problem , but only in traffic ,its okay on highway & free roads, someone has suggested me to remove springs from raditor, i have not tried thing.?
Varun560061
Try getting the radiator overhauled, get the springs in it removed.
Then check if its still over heating. If yes check radiator cap & thermostat valve.
Better replace these two.
Machakos,kenya
2014 maruti overheating
Hello guys..
Please help me out.I have a maruti in kenya which i bought in the year 2014 and it has been perfoming good since then it developed issue on overheating and when i stop over the temparature gauge goes up quickly to level hot.If i proceed travelling it comes to normal.i have chnaged two cylinder head gasket but just to found each gasket is fine,does not mix water and oil.I use water as coolant in the radiator and the level of water doesnt go down at all.I have removed wires in the radiator,and the water pump is in good condition,pumping water fully.After stopping the vehicle,it takes more than 3 hrs to cool the water in the radiator.Uses mechanical fan,which is in good condition.
What might be the problem?..Please help me before i fall in false hands of techinians.
Thanks.
