Maruti Suzuki Alto LXi Wine Red Ownership Review
Thread Starter #20
Villupuram, Tamilnad
Adjust the clutch play 10 to 13 mm and observe. You can adjust at leaver at gear box or at pedal. If problem solves well and good.
Thank you for your immediate reply sir.
I adjusted the clutch free play to 10mm in the existing clutch set. Though the thud sound reduced, clutch release bearing failed after some kms and I noticed little clutch slippage.
Actually when the existing clutch was opened, the clutch plate and cover assembly was found healthy. It is only the release bearing which was damaged. Anyway replaced all the three along with wire.
Don't know why the new clutch is also giving the same thud sound.
It will be helpful if anyone confirms the thud sound is present in their Alto.
This sound was observed in my Dzire, I have adjusted 10mm play, slowly noise reduced overtime. The spare parts are actually rejected parts falling beyond 5% standard deviation curve when manufacturing. These things they send it as spares.
