Maruti Alto A/C Problem
Ludhiana
Oh okay. Thanks sunny2525 [clap]. I will check it out right away and let you know. Can you tell me how much the thermostat costed you ?
The thermostat was about 200 Rs and the labour was 100. I did not get it done from the Service Center but from a very famous AC specialist in my City. It was done some 3 years ago so no idea how much does it costs today.
Alto Headgas kit
Hi ,
I have alto 2005 model 65000 km done
Since last month i am facing heating problem due to this change head gasket week ago now heating problem solved but i know i noticed that oil is coming in radiator in mixing with coolant
Now what to do as already change the head gasket twice ?
Varun560061
I guess the engine head has bent, get the engine head shaved for 0.2 - 0.3 mm so that it seats evenly on to the engine.
Get it done from a reputed machine shop (lathe).
Thread Starter #19
Guys, i checked with an AC specialist and he has told me change the thermostat as you guys said. 200 rs ?!! [shock] He told me 1200 rupees !
Go to an MGP store and buy the thermostat and get it fitted at any garage.You will only have to top up the coolant.
Try: mgp.co.in
to find an MGP store in your area.
Managua
Ac problem Alto 800
Currently my car is 2 years old, Alto 800 2016, 60,000km, but recently the air coming from the vents is less. I can hear the blower functioning but the air won't come from the vents. The cooling is fine, the heat is fine. I can hear the compressor engaging when I turn the A/C on. Can someone share if they have the same problem and post a solution?
Hi,. I'm facing the same problem.
Alto AC, after sometime in drive , blower stops working and I could only sound.
Can someone please let me know how was it solved.
Guys, please help.
Thread Starter #23
Ac problem Alto 800
1. Low on gas,So the coil is freezing and no airflow through the vents. Check the gas level.
2. Thermister gone bad. Replace it.
Keep us posted on the developments!
Most of the time front part of the cooling coil(evaporator) is blocked by dust and fungus. Wash it with some soapy water if possible without removing the coil.
