Maruti 800 Shockers Problem
delhi
Guys
My old maruti sometimes bounces a lil when at high speeds 100kmhr+.
Should i change the shockers ? How much does a maruti 800 shocker cost ?
delhi
Guys
i am facing 1 more problem in my maruti that the gears are not shiftign smoothly. My friends told me that my gear bushes need to be chnaged. So should i chnage the gear bush ? How much gear bushes cost?
I suggested you start new thread for the gear problem as the primary focus will change.
Try doing wheel balancing first (200-250 Rs) job.
Guys
The issue is not related to the suspension. IMO get the wheel alignment and balancing done at a reputed tyre shop. You will feel noticeable change in the behavior of your car at high speeds.
delhi
one more problem
my handbreak is not working atall . what could be the problem
dehradun
for the handbreak problem there may be one issue the wire attached to the lever it may be broken or may the outer is rusted and may be reuirement is now to change it it can be found out by pulling up the lever if rthere is no tension then wire internal is broken however there is tension but no action then outer has gone wrong please look at this
