DIY for wooden dashboard & Centre console.
Hi,Friends
Since so many days I was planning to do DIY for Wooden dashboard,
I have started from centre console today as I was not sure enough about the work (so better to start with smaller parts)
What you need
1) Wooden floor paper (Carpet)
2) Synthetic rubber adhesive like Fevicol SR 505.
3) Thin grit sandpaper - for sanding dashboard surface
3) Brush - to apply adhesive
4) Sharp blade & Scissors - for cutting carpet.
5) Isopropyl Alcohol - to remove oil & grease from dashboard surface.
How to proceed
1) Clean the dashboard to remove dirt
2) Clean all surfaces of your dashboard thoroughly with isopropyl alcohol and a clean
towel to facilitate adhesion.Oil, grease and dirt will all keep the adhesive from sticking
properly to the dashboard.
3) You will need to sand (very little sanding) the dashboard with sandpaper.(only the part where you want to apply wooden paper) before you apply gum on surface.
4) Apply thin layers of adhesive on both dashboard and paper and leave it for drying 5 minutes before pasting.(See the instructions on adhesive containor)
5) Paste the paper slowly beginning from one side. (like applying scrath guard on mobile screen) and use a clean cloth to press the paper to dashboard.
posting few pics (work in progress)
The color difference in two pics is because of cloudy & clear weather
