Left Foot Braking
Arun
What is left foot braking? How to brake using the left foot?
Source-1[ModernRacer]
Left-foot braking is primarily used in front-wheel-drive cars and comes in handy during cornering at high speeds.
A severe problem affecting most front-drivers is understeer during fast cornering. Understeer generally means that during cornering at a high speed, the car has a tendency to keep moving straight and to the outer edge of the curving road rather than the direction in which you are pointing the car. To cancel out understeer, there should be more grip at the front wheels than at the rear. The left-foot braking technique more or less helps you to do just that.
When approaching a corner, you should start slowing down like you normally do, using your right foot to apply the brake. At this point, you can use the heel-and-toe maneuver and downshift to the proper gear. Now, you should move your right foot over to the accelerator and your left foot to the brake at the same time. You are now ready to perform left-foot braking. Continue slowing the car down to a reasonable - but not too low - speed by applying the brakes with your left foot. As you are about to turn into the corner, hit the gas with your right foot and keep braking with your left foot at the same time. Being a front-wheel-drive, the rear wheels will lock while the front wheels keep moving. The car's weight is transferred to the front, causing the front wheels to have more grip than the rear wheels. The car now starts to oversteer.
Now you have to keep the car in control by steering in the direction that you want to go, and applying more or less throttle and braking as needed. You have to use both your pedals at the same time, which will take practice. Lifting off the accelerator will cause more oversteer and flip out the car's rear even more. Applying more throttle while easing off the brakes will reduce oversteer and straighten out the car. Keep performing this balancing act to smoothly clear the corner at high speed, all the while making little corrections to your steering. At the end of the corner, just floor it and power out.
When you get good at this technique, you should be able to just keep the accelerator completely floored and keep the car moving in your preferred direction using just your brake pedal and steering wheel. Understeer is eliminated if done correctly and you clear the corner at a higher speed than in normal driving. The trick is to keep practicing braking with the left foot and learn to apply the brakes as well with the left foot as with the right.
With a typical race-car gearbox, you can even start your initial braking with your left foot instead of your right without having to use the clutch pedal. When braking, you can blip the throttle between the gear change. Most normal gearboxes cannot cope with such abuse and so it is generally better not to even think about trying such a move with your commuter car unless you have deep pockets to foot the resulting repair bill! Also keep in mind that many upmarket cars are equipped with computer-controlled stability systems that will help you to safely keep a car in control during high speed cornering. But with practice, you can control a car better with the stability system turned off and turn at an even higher speed.
Source-2[DrivingFast]
Left foot braking is a technique used frequently in rallying, but can be equally useful on the road or track for:
* Reducing understeer into a corner
* Reducing drive loss through spinning wheels
* Removing the pedal transfer time between accelerator and brake
The theory here is that you can feather the brakes into a corner (trail braking), while transitioning to progressive throttle at the apex. This can lead to a very smooth transition between braking and acceleration and is less likely to unsettle the car through unwanted weight transfer. It also keeps the weight at the front of the vehicle for as long as possible, thus providing more grip, a better turn in and reduces the possibility of understeer.
This technique is particularly useful for a front wheel drive car without a limited slip differential. On the exit of the corner, it is a common symptom for one the unladen front wheel to spin while applying throttle. This spinning wheel is preventing all of the power from transferring to the road and thus slowing the exit speed. By feathering the brake with the left foot, this can prevent or reduce this wheelspin, and get a better exit.
Using the left foot to brake removes the pedal transition time from brake to accelerator and vice versa. This can shave fractions of a second off a lap time when done well, but cannot be used when it is necessary to change down a gear (unless you decide not to use the clutch!)
Common mistake when learning to left foot brake
Left foot braking is an advanced technique, and should only be attempted in anger after lots of practice. When learning to left foot brake, you'll initially press the pedal far too hard as you'll be used to the action of pressing a clutch all the way to the floor. It takes time to re-programme the muscle memory of your foot and leg, and a bit of empty tarmac is recommended.
[YT]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/vcSAiRxmm0w&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/vcSAiRxmm0w&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YT]
[YT]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/BMEqOGejlrw&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/BMEqOGejlrw&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YT]
Hope you understand! Though this may not be applicable during general road use, but will help you save time during an emergency. Just find a corner to turn around![lol!]
Respect your Ride.
Keep burning asphalt!!
Arun.
what about the rear wheel driven cars then??
Rear cars don't have a problem of understeering,its always the opposite with RWD cars.Hence doing this on a RWD will transfer the weight in the Front reducing the traction on the rear tyres.Don't try it in RWD cars!! (or at your own risk) btw the verna is a FWD
@ Napster, try it on open roads because the very first time you try it you'll brake hard ( experience).And its best to learn it barefooted
Bokaro/Angul
@Renegade
1st Point- Invalid. LFB is equally used on RWD cars, same reason[Weight Transfer], but different outcome. In FWD, it removes understeer during high speed cornering. In RWD, It helps u put the car into a controlled oversteer[ read drift] for the same reason, faster cornering.
2nd Point-Hmm..
I'm not alone.[lol]
Before You can completely capitaise on LFB, go down and learn Heel & toe shifting. Another advanced technique, that makes you go faster.
And for all Drift Maniacs out there...
Using these together, U can drift quite well in FWDs.[ Real drift cornering, no ****py wank-the-handbrake stuff.][cheers]
napster
AP-09
tried left foot braking some time ago dude, it was breath taking so never tried it again ..now that i know it has some advantages for cornering, and me being a cornering fan , ill surely master the art :)
raj_5004
Dubai / Mumbai
be careful guys! our left foot is accustomed to depress the clutch fully unlike the right foot which 'feathers' the brake pedal & throttle. once on an isolated road & thankfully at slow speeds, i tried braking with my left foot & the car came to a sudden halt. how much ever i tried, i always pushed the pedal hard. maybe with practice, i can. so please do not try this on crowded roads.
Nice info !
Well as Raj said, Dont try stunts in middle of traffic!
Its really tough to get acustomed to a new method!
Practise Safe :)
napster
AP-09
as zinam's signature says, safety isnt expensive, its priceless.. so dont ever dare to try this in a busy area. once you master the art, the roads are yours :p
@Renegade
2nd Point-Hmm..
I'm not alone.[lol]
For people who have no clue what heel and toe method refer this thread.
napster
AP-09
tried this an hour ago, trust me guys its not as easy as it looks, needs lots and lots of practice and obviously some timing skills. one wrong move and our completely out of control.
Its not only completely out of control!
You will end up in a big mess :)
Our left legs are used to press & depress hard for clutch movements & you cannot try LFB in just a day or so.
More over, i will say this is not at all required as we are just going to drive on roads & not race [cheers]
Bokaro/Angul
Dude, Its not required, its recommended.
it makes you have much more control over the car even in day to day situations. Understeer is the last thing i'll want during a high speed turn, and everybody enter a corner with gusto if they find it deserted. We are petrolheads after all.[cheers]
Nothing Like car control.
