I'm a complete noob when it comes to wiring and foglamp installation. But I don't mind learning it!
I wanna install a IPHCAR 3.0" Lo/Hi beam dual function projectors that i'll be buying off amazon and use H11 LED bulbs on it (not using HID thus bypassing ballast and stuff). They won't be coming with wiring i think.
My car Baleno Delta 1.2 manual 2015, I don't think it has wiring harness for foglamps.
1. What kind of wires do i need for this setup?
2. How am i suppose to pass wire from engine compartment to dashboard, drill a hole in the firewall?
3. Should i go for a relay for high beam or a seperate switch?
4. From where I should tap the power source?
A wiring diagram would be helpful and I dont want to cut any wires, going to use MGP OEM foglight switch for OEM look!
Thanks!
Thanks!
