hey Rajan Congratulations on the Ice Upgrade this car really needs one lol!!! made me feel really bad when I sat in my Friend's Swift Zdi and it had better sound than the Scorpio S10, Sorry I recently bought a S10 4x4. I have pretty much upgraded most of the things that pinched my eye but am left with a few...now its time for the Sound to get upgraded. Now unlike you I don't want to put a subwoofer or an amp but, want to upgrade the Fronts with Polk Components and the rear with 6x9 instead of the round and in the door itself(My family is against box fitments) after damping. Now I need you suggestions on certain point if you don't mind.
1. How much of a difference in sound quality have you noticed after swapping the old ones with components?
2. Are your rear 6x9s on the sub woofer amp or direct from the HU? if Direct, then is there a sound difference there too? (Sorry for the repeat of question, but am trying to understand if the entire input of cost = to the return is sound)
3. Is the HU capable of producing enough effect to the speakers as they are each 100W rms input, I know i won't be able to get optimum sound out of them without an amp, but I really don't enjoy music anymore in the Scorpio and want to know if you know what is the HU's output per speaker?
Well I hope I haven't zapped you but I have been pondering over this since last 10 days and can't get proper suggestions without anyone suggesting to get an amp, so please do advice.
Thanks
Kanboy.
Thanks
Kanboy.
Am sorry to say this but a Scorpio is one of worst and unfriendly vehicle for an ICE system upgrade, 1 because of its shape and size and 2 because the manufacturer M&M either has no sense of music or is simply bad at designing a car suitable for good music (maybe still stuck up with tractor innovations). Now coming to your queries please note the replies as below in order:-
1. Stock speakers provided by Mahindra compared to the ICE upgrade has a phenomenal difference of a transistor to a digital Dolby DTS sound system of a theatre. The Sound quality and performance improvement levels can be clearly heard due to upgrade of 2 amps, sub, components, rear co axial (all Rainbow) and DSP (Mosconi).
2. My rear speakers are now powered by an amp. Initially I had the amp powering the front compos and sub woofer and the rear speakers were directly connected to the HU. As the fill output from the rear was not satisfactory I have now installed a mono amp beat1+ to power the sub and rear speakers are powered from the 4 channel amp Beat4. Partially the problem was because I had installed round speakers at the rear and not 6*9, as was not comfortable with cutting into the tailgate panels. 6*9 are the best option at rear if your ice is without a sub.
3. Regarding the capacity of the stock speakers provided by Mahindra, they are Onkyo brand with maybe 30 rms and not 100 rms. It's the max power output that is mentioned on them.
So to sum it up on upgrading ICE in a Scorpio, better avoid it! Simply use the stock set up till they die and then think of what to do next. After spending 1.2 lakh on Ice upgrade I still don't get the feel of music due to the bad speaker placements provided by Mahindra. Incase you wanna upgrade consider to at least install a amp to power the components and good quality wiring kit.
