Hyundai i20 Audio Upgrade
MUMBAI
hey this is a thread for the upgrades on the audio part on my i20 crdi sportz purchased on november 11th 2011
ive always been a person who would give up exterior modifications just so as i
can have the best audio equipment in my car to my budget and liking
ill be posting pictures in a day or two
as on now my car has a pioneer avh 8490 bt touch screen head unit
2 sets of components
front focal performance 165 v30 series
and the rear running focal polyglass 165 vb
being powered by a focal solid 4 amplifier
also an infinity sub woofer the 1264w model in a custom top vented enclosure
running of a mbquart mono 1000.1d amplifier
ive used this setup for almost 16months
and wanted to upgrade the speakers
which will happen tomorrow @ my friends accessory shop
my doors and boot lid have already been filled with dynamat
and yes it makes a hell of a difference
dont believe me ask topgun from our forum
he did the same to his fluidic verna after hearing the difference in my car
next step of upgrade focal krx2 components in the front and
the focal kr components in the rear door
will update with pics once the work is done in the next few days
[cheers]
Hey ! I am planning to get 8490 BT in my i20 as well. Does it work well . What is your review on this ? I own an iphone 5 not sure if you can help but can you tell me if it is compatible.
MUMBAI
hey diehardi20 the ive been using the 8490bt since 9 months now
the unit is great but doesnt work well with the iphone 5
they have to update the firmware still for this model which should happen
soon
soon
A bit confused? Are you using Focal polyglass VB 165 components in rear?
Sankar
MUMBAI
i was using Focal polyglass VB 165 components in the rear
currently using performance P 165 V30 components in the rear door
waiting on the krx2 to arrive to be fitted on the front door
MUMBAI
The 165 v 30 is the performance series not the polyglass I bought them 3 months ago for 16 k
The krx2 Is about 34k but still waiting for it to arrive and get final pricing
Wow and you will be powering them with Focal Solid 4 amplifier? Doesn't the components needs much more power than what Solid 4 can manage?
Sankar
MUMBAI
Sankar
as per my knowledge the krx2 is 100w rms @ 2ohms
and the solid 4 amplifier also has stable power of 100w rms @ 2ohms
where as the performance 165 v 30 is 80w rms @ 4 ohms
and the amp gives 75 w rms
so it should support it if not will upgrade @ a later stage
In case you are looking for an amplifier with 100w RMS the you can try DD Audio C5C which now costs 15k. I have heard they might increase the price to 20k soon[frustration].
Sankar
MUMBAI
Sankar
hey sankar
havent used the dd amps so not sure if i do upgrade it will be a focal fps amp fro sure
also as of now the solid 4 supports 100rms so i dont think it should be a problem
hey sankar
Sounds good as upgrading an amp is very costly and also second hand amps won't sell for much. So unless you really need more powerful amp only then one needs to upgrade. Hope i am right[;)]
Sankar
mumbai
all this Focal - solidglass - etc is Latin to me...... Pardon my ignorance, but i need your help
i have a i20(2011) 1.2 magna. the front and rear speakers are really really good..... (by my standards [;)])
will changing the speakers to JBL make any difference? i use media from the net and other various sources stored on my 8gb thumbdrive.
i do not want any fancy amp/preamp/booster etc. stuff
thanks in advance
Thread Starter #14
MUMBAI
hey hdesai
yes changing the company speakers to another branded ones will make a difference
maybe marginal but it will
you have to remember that your front speakers are a component set i.e speaker separate and tweeter separate
and the rear is a coaxial where the tweeter is part of the speaker itself
so take the same setup and it will sound much better than the company setup
