How To Embed Pictures and Videos
Sharing pictures, files and videos across the forum is a straight-forward procedure. However, please do note that:
  • Maximum permitted file upload size is 5 MB.
  • You can add maximum 100 attachments per post.
  • Image dimensions are restricted to 1000x1000 pixels.
  • System will attempt to resize or reject anything beyond the limit.
  • You may use tools like File Minimizer or Simple Image Compressor to resize images without affecting their quality.
  • Supported file types include: .zip, .txt, .pdf, .png, .jpg, .jpeg, .jpe and.gif.
Uploading Pictures & Files
To upload files or pictures in a message, click “Attach Files” button right below the post editor and select desired files from your PC.
You can choose to either attach large thumbnails or full size image. If no option is selected, small thumbnails are automatically attached at bottom of the post. Example:
If you wish to share an image which is already hosted elsewhere on TAI, use URL option under "Insert Image" button on post editor instead of re-uploading it.
You can even embed images uploaded by yourself or others in the “Garage” using “Gallery Embed” icon.
We’re strictly against hotlinking (bandwidth theft) and therefore recommend sharing all images by uploading them only through our own system.​
