Hello TAI,
Its been long since I've used the forums. Anyway I've had my cituy gxi 2005 for 2 years now. Had to even swap my engine (thailand imported engine with 89 bhp compared to the indian 77 bhp engine) . Now the car needs and major suspension work and i need some help. My car load is more then average as we are a heavy family plus there is a cng kit installed I wanted to know are there any aftermarket suspension tat can take more weight then the stocks and what about shock dampers can i find some longer in height then the stock as this model tends to scrape too much. Other mod i wanted to try was to fit ivtech L15A7 engine as this mod is done on a brio (1.2 stock engine to city 1.5 engine) is the engine direct bolt on , because they look typically the same and i guess ill even need the ivtech ecu , this mod is not on urgent basis but something i really wish to do, ive already swapped the engine once so i know the process but this is an different engine so i need some help ie is it bolt on, will other mechanical fit like the ac compressor and fan , will the chassis support the extra top speed that ill get with it . Thanks
